I have noticed a situation that happens.
I have a wireless zone that has been causing me issues. A couple times a day it doesn't check in and then I get the check 20:
Basically once this happens I am locked out of any hard wired zone triggers from working until I bypass the zone and hit *
You can see here from the logs that I bypass the zone. It then says Disarmed Bypass Hit *for faults. As soon as I press the * you see it registers that the back door and master bathroom window are open. Note: they were open from the beginning.
I use the backdoor trigger to turn on outside lights at night and I noticed it hasn't been working. I think I figured out that when the check 20 happens, it basically locks up any events from acting on zone faults until the check 20 is cleared and the * is pressed.
[COLOR=#000000]May-12 9:51:11 AM[/COLOR] [COLOR=#000000] [/COLOR] [COLOR=#000000]Vista Alarm[/COLOR] [COLOR=#000000]CHECK 20 MASTER BEDROOM WINDOW[/COLOR]
May-13 12:35:23 AM Vista Alarm FAULT 14 BACK DOOR May-13 12:35:19 AM Vista Alarm FAULT 09 MASTER BATHROOM WINDOW May-13 12:35:18 AM Vista Alarm Sending Button Send command to alarm May-13 12:35:10 AM Vista Alarm DISARMED BYPASS Hit * for faults May-13 12:35:08 AM Vista Alarm 0739396,00 received from Stairway Stairway IR RF May-13 12:35:05 AM Vista Alarm 0739396,80 received from Stairway Stairway IR RF May-13 12:35:03 AM Vista Alarm BYPAS May-13 12:35:02 AM Vista Alarm Sending BypassZone command to alarm May-13 12:34:49 AM Vista Alarm Sending Button Send command to alarm May-13 12:34:49 AM Vista Alarm Sending Button Send command to alarm May-13 12:34:49 AM Vista Alarm Sending Button Send command to alarm
