Keypadlinc affecting ramp to dim in Insteon Group
well this is a new one...
Please post your insteon.ini when you have one of the KPLs registered that is causing this behavior. Also identify the KPL you just added and one of the groups that is having an issue.
also, what version of the plugin are you using?Mark
HS3 Pro 4.2.19.5
Version is 1.5.6.0
Here are the before and after on the ini files
http://db.tt/CPveU0ck
http://db.tt/TBYoLjwD
I named the unit keypadlinc and its in house... There are only two insteon groups and they are both affected when the keypadlinc is added.
I have rdp on the server and can give you a public address if you would like to log in to it.
Chris
Chris,
this might actually be a bug with the setup of the controllinc. when did you add that device?Mark
HS3 Pro 4.2.19.5
Originally posted by Chris Couture View PostIt's probably been in the system for about 3 weeks. It did some funky stuff when I added it but I was able to get it to work and it's been working fine. I'm not opposed to removing it and adding the keypadlinc to see if that resolves the issue.
Chris
then register your kpl and test your group. my guess is it will work fine.
i can post a build that should fix the controllinc issue, but we need to test this first.Mark
HS3 Pro 4.2.19.5
I removed the controllinc and added the keypadlinc back to the system and checked the events that control the group and they seem to work now. I'm at work but from what I can see on my cameras, the lights are turning off and on when I trigger events that were not working.
So, does that mean that the controllinc isn't compatible?
Originally posted by Chris Couture View PostI removed the controllinc and added the keypadlinc back to the system and checked the events that control the group and they seem to work now. I'm at work but from what I can see on my cameras, the lights are turning off and on when I trigger events that were not working.
So, does that mean that the controllinc isn't compatible?Mark
HS3 Pro 4.2.19.5
Chris,
please give this a try, and post your results.
install the attached build. then register you controllinc and retest your group as necessary
please post the controllinc device section from the insteon.ini. i would like to see the registration infoAttached FilesMark
HS3 Pro 4.2.19.5
Sorry for the delay, I didn't realize you had posted the new file.
I replaced the dll with the the new one and added the controllinc. Everything seems to be working...
[Device 87]
DeviceID=05.1D.AF
DeviceName=Controllinc Master Bedroom
DeviceLocation=Master Bedroom
DeviceType=0004
FirmwareVer=23
DatabaseDelta=43
LinksDownloaded=1
PollingInterval=0
Protocol=1
EEValues=
RecentDatabaseDelta=43
NumLinks=8
Link 1=E2 01 19 55 BB 01 00 00 1
Link 2=E2 02 03 47 8F 02 00 00 2
Link 3=E2 05 05 E2 CD 05 00 00 3
Link 4=E2 01 18 D2 C1 FF 1F 01 4
Link 5=E2 02 18 D2 C1 FF 1F 02 5
Link 6=E2 03 18 D2 C1 FF 1F 03 6
Link 7=E2 04 18 D2 C1 FF 1F 04 7
Link 8=E2 05 18 D2 C1 FF 1F 05 8
ChannelName1=
ChannelName2=
ChannelName3=
ChannelName4=
ChannelName5=
SyncLinkedDevices=0
Thanks for the quick response and fix!!!
Chris
Originally posted by Chris Couture View PostSorry for the delay, I didn't realize you had posted the new file.
[Device 87]
DeviceID=05.1D.AF
DeviceType=0004
FirmwareVer=23
DatabaseDelta=43
LinksDownloaded=1
PollingInterval=0
Protocol=1
EEValues=
NumLinks=8
ChannelName1=
ChannelName2=
ChannelName3=
ChannelName4=
ChannelName5=
SyncLinkedDevices=0
Chris
thanks for the feedback. glad its working. Please use the subscribe feature to get email notifications when someone responds to your threads.Mark
HS3 Pro 4.2.19.5
