MeiHarmonyHub v3.0.3.8 is now available in the HomeSeer store and in the updater (Beta Section)!
IMPORTANT NOTE BEFORE UPDATING TO THIS VERSION
Due to the settings being moved to files, there is a chance that upgrading from any version prior to 3.0.3.5 may NOT work. I have done my best to test locally, but as a precaution it is heavily recommended that a backup be completed before upgrading.
At worst, what will happen is that settings are lost and it will have to be set up again. This is a one time update to move to the new settings storage location which will hopefully prevent some of the issues some have had with lost settings.
The following are included:
Please see the full descriptions here:
https://forums.homeseer.com/showthread.php?t=194095
Release notes Here:
https://forums.homeseer.com/showthread.php?t=194096
- Changed so that Settings are stored in files instead of in the devices themselves
- Upon first run of the plugin after update, it will attempt to copy over settings into the files.
- Adjusted the layout of the settings page as recommended here: https://forums.homeseer.com/showpost...0&postcount=14
Release notes Here:
