UltraCID3 HSPI version 3.0.6681.34300 makes several changes to device addresses. Please make sure you have about 15 minutes of time before attempting the upgraded because you'll need to manually delete the old devices and then re-save any events so the newly created devices will be used. You'll also need to go into the plug-in options and re-select the Com Port for modem #1.
Note: You'll also need to update any events that use the device address because the address was changed as follows:
UltraCID3-Attr
UltraCID3-Name
UltraCID3-Nmbr
UltraCID3-Ring
To:
UltraCID3-Attr1
UltraCID3-Name1
UltraCID3-Nmbr1
UltraCID3-Ring1
Ultrajones
UltraCID3-Attr
UltraCID3-Name
UltraCID3-Nmbr
UltraCID3-Ring
To:
UltraCID3-Attr1
UltraCID3-Name1
UltraCID3-Nmbr1
UltraCID3-Ring1
Ultrajones
