Go Back   HomeSeer Message Board > Security Systems Plug-ins > Security System Discussion > HAI/OMNI Panel for HS3 Plug-in (rmasonjr)
HAI/OMNI Panel for HS3 Plug-in (rmasonjr) Discussion about Rob Mason's HAI/OMNI Panel Plug-in
Old April 22nd, 2018, 04:09 PM
spagettilegs spagettilegs is offline
Seer
Plugin can turn lights off but not on?
I updated my plugin today as I was getting an error message "WARNING: Failed getting InterfaceStatus from OMNI - the interface was not found in the list of active interfaces, the list may need to be refreshed."
The update installed ok but now the plugin can't turn lights on...only off?
Any ideas?
Old April 23rd, 2018, 09:18 AM
rmasonjr's Avatar
rmasonjr rmasonjr is offline
OverSeer
The latest version is having issues with Dim/Brighten/Level. Please send me your logs using one of the methods here:
https://forums.homeseer.com/showthread.php?t=186423
64 Z-Wave Nodes, 162 Events, 293 Devices
Old April 23rd, 2018, 10:36 AM
Seer
Logs via Email
I followed the instructions. I think the logs were sent but I didn't get any confirmation notice.
Could you let me know if you received them?
Old April 23rd, 2018, 10:59 AM
rmasonjr's Avatar
OverSeer
No, nothing was received...
Old April 23rd, 2018, 11:07 AM
Seer
Strange? It says the event has been run. I think I've set it up correctly? (see image)
Old April 23rd, 2018, 11:25 AM
rmasonjr's Avatar
OverSeer
That looks right - check your HS logs and see if there are any errors.
Old April 23rd, 2018, 11:51 AM
Seer
These any help?
Unable to connect to POP server(1) Error: Object reference not set to an instance of an object
Apr-23 4:32:54 PM Info Amazon Echo Discovery requested, version: 2
Apr-23 4:31:23 PM Error Unable to connect to POP server(1) Error: Object reference not set to an instance of an object
Apr-23 4:29:41 PM Info System connected to MyHS Service successfully with license ID 110017.
Apr-23 4:29:41 PM Info System connected to MyHS Service, waiting for acknowledge...
Apr-23 4:26:51 PM Error Creating connection to MyHS service, there may be a problem with the server or the Internet connection. The connection will be attempted again shortly.
Apr-23 4:21:12 PM Error Unable to connect to POP server(1) Error: Object reference not set to an instance of an object
Apr-23 4:15:00 PM Log Info The log database is currently 0.16MB in size.
Apr-23 4:11:01 PM Error Unable to connect to POP server(1) Error: Object reference not set to an instance of an object
Apr-23 4:01:11 PM Warning Sending email To: robmasonjr67@yahoo.com aborted after 4 tries
Apr-23 4:01:11 PM Error Exception sending email via GMail (To:robmasonjr67@yahoo.com, cc:, bcc:, Sub:HAI Logs, Attach:/usr/local/HomeSeer/Logs/OMNI.log) = Username and Password not accepted. Learn more at
Old April 23rd, 2018, 12:13 PM
Seer
The same thing is happening with the Alexa "smart Home" skill. Would this mean it's a Homeseer issue?
Everything works perfectly with the Leviton app.
Old April 23rd, 2018, 12:14 PM
rmasonjr's Avatar
OverSeer
No, it's not a HS issue - it looks like your GMail username/password is invalid.
Old April 23rd, 2018, 02:40 PM
Seer
Looks like the logs were sent successfully. Gmail was blocking the email as it was a "less than secure" app. I've changed the security settings.
Old April 24th, 2018, 02:04 AM
Seer
Everything ok in the logs settings?
Old April 24th, 2018, 10:12 AM
rmasonjr's Avatar
OverSeer
No, set the logging to DEBUG and let it run for a while. Try some lighting controls, then send the logs again.
Old April 25th, 2018, 12:15 PM
Seer
Just checking to see if you received the email with the log details?
Old April 25th, 2018, 01:18 PM
rmasonjr's Avatar
OverSeer
Quote:
Originally Posted by spagettilegs View Post
I did - thanks - I'll post back here when I have a new release to try.
Old April 26th, 2018, 08:58 AM
Seer
Great...thanks.
  #16
Old April 28th, 2018, 07:54 PM
phoek phoek is offline
Viewer
Can turn lights off but not on.
I am having the same issue after updating to the latest version of HS3. I can turn lights off but not on through any interface. I am running the newest version of HS3 and the OMNI plugin.
  #17
Old May 3rd, 2018, 10:08 PM
serky serky is offline
Seer
same issue. off but not on.
HTML code is On
WD-100+ Dimmer lights turn on, but don't turn on lights in ceiling blueridgeatx HomeSeer Wall Dimmers & Switches 13 December 13th, 2016 12:09 AM
How do you turn all the lights off daferris JowiHue Plug-In 1 June 26th, 2016 01:25 PM
Turn Most Lights On/Off macrho HS3 / HS3PRO Discussion 3 July 13th, 2015 02:48 PM
Turn off outside lights after an Alarm event ONLY if lights are supposed to be off bradhs HS2 / HSPRO 1 April 27th, 2007 03:16 AM
How do I turn off lights when I arm M1? crcth3894dthdtnd Elk M1 Plug-In 20 July 24th, 2005 05:21 PM
