I've just upgraded to HS3 and have it installed on a Qotom Q350P micro PC running Win10Pro. Everything seems to be running fine, except that the ADIO-100 I have on the COM3 Port usually disconnects as some point (often within 12 hours of running). I have no idea of what's behind the disconnect. The connection was initially with Cat5e cable using DB9 to RJ45 converters. Suspecting that there may be some cable interference, I swapped this out to a plain DB9 M/F serial cable. The baud rate on both the ADIO and PC is set at 11500.
I should note that the ADIO performed flawlessly on my old Hometroller S4 running XPe and HS2. The HS3 ADIO plug-in is currently set to poll every 15 seconds, but I've tried 30 seconds with the same results.
Any ideas??
Any ideas??
