Go Back   HomeSeer Message Board > Security Systems Plug-ins > Security System Discussion > HAI/OMNI Panel for HS3 Plug-in (rmasonjr)
HAI/OMNI Panel for HS3 Plug-in (rmasonjr) Discussion about Rob Mason's HAI/OMNI Panel Plug-in
Old May 15th, 2018, 02:05 PM
amarch amarch is offline
plugin keeps cycling
I have an HAI Omni Pro II v 3.15
the plugin keeps cycling here is the log any ideas as to why this is happening?
May-15 2:02:16 PM Info Plugin OMNI with instance: has disconnected
May-15 2:02:16 PM OMNI ---------------------------
May-15 2:02:16 PM OMNI Plugin startup is complete.
May-15 2:02:15 PM OMNI ---------------------------
May-15 2:02:15 PM OMNI Synchronization complete.
May-15 2:00:17 PM OMNI Synchronizing OMNI devices with HomeSeer...
May-15 2:00:16 PM OMNI Requesting initial system troubles
May-15 2:00:12 PM OMNI Requesting Output status...
May-15 2:00:11 PM OMNI Requesting Area status...
May-15 2:00:11 PM OMNI All configuration and properties retrieved.
May-15 2:00:10 PM OMNI -->Reading properties...
May-15 1:59:21 PM OMNI -->Reading configuration...
May-15 1:59:15 PM Starting Plug-In Plugin OMNI started successfully in 2248 milliseconds
May-15 1:59:13 PM Warning Attempt by plugin to register a duplicate link of OMNI. Plugin: OMNI Instance:
May-15 1:59:13 PM Starting Plug-In Initializing plugin OMNI ...
May-15 1:59:13 PM Info Plugin OMNI has connected. IP:127.0.0.1:48206
May-15 1:59:12 PM Warning I/O interface OMNI is down, executable is not running, restarting ...
May-15 1:58:43 PM Info Plugin OMNI with instance: has disconnected
May-15 1:58:43 PM OMNI ---------------------------
May-15 1:58:42 PM OMNI Plugin startup is complete.
May-15 1:58:42 PM OMNI ---------------------------
May-15 1:58:42 PM OMNI Synchronization complete.
May-15 1:56:44 PM OMNI Synchronizing OMNI devices with HomeSeer...
May-15 1:56:44 PM OMNI Requesting initial system troubles
May-15 1:56:39 PM OMNI Requesting Output status...
May-15 1:56:38 PM OMNI Requesting Area status...
May-15 1:56:38 PM OMNI All configuration and properties retrieved.
May-15 1:56:37 PM OMNI -->Reading properties...
May-15 1:55:49 PM OMNI -->Reading configuration...
May-15 1:55:44 PM Starting Plug-In Plugin OMNI started successfully in 2255 milliseconds
May-15 1:55:42 PM Warning Attempt by plugin to register a duplicate link of OMNI. Plugin: OMNI Instance:
Old May 15th, 2018, 02:42 PM
rmasonjr's Avatar
rmasonjr rmasonjr is offline
It's almost like the plugin is timing out for some reason.
Is HS running on a Windows PC or a Zee?
Are there any other plugins running?
You can try to disable/restart the plugin with the following:
Go to Plugins->Manage
Disable the plugin by clicking the checkbox.
Wait a few moments, then enable the plugin.
Your logs posted indicate it takes about 3mins to completely poll your panel and devices. Give it a little while to startup and check the logs again.
HTML code is On
Z-net Cycling Red/Green LED DanWheeler Z-NET 5 February 22nd, 2017 12:34 PM
Problem with power cycling my Z-Net John Dion Z-NET 5 May 29th, 2015 03:11 AM
Automate Router Cycling smoothtlk General Home Automation Hardware Discussion 2 September 17th, 2005 04:32 PM
Help cycling XCams fit4life Script & Plug-In Library Discussion 9 March 21st, 2003 09:01 PM
X10 Camera Cycling script JeffCharger Script & Plug-In Library 0 November 4th, 2002 03:13 PM
