A new version of the HAI plugin was submitted to the updater this afternoon. It may take a day or so
before it shows up. I am no longer providing the updates here to keep things a little cleaner.
Changes in this version:
***Backup your current installation so you can revert back if needed!!
Note: As of HS3 v3.0.0.312, HST has removed backups of the plugin updates.
For this reason, rolling back to previous versions is dependent on the user making a backup
before upgrading in the updater. Always make a backup of your HS folder before installing updates.
- Fixed - issue with triggering arm/disarm events (lakemirror)
- Added - setting low/high setpoints for temperature/humidty sensors (dean)
