jesus this is so crap right now
lets hope stipus can help out
check this log after deleting
PHP Code:
C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V110\Microsoft.Cpp.Platform.t
argets(44,5): error MSB8020: The builds tools for v120 (Platform Toolset = 'v12
0') cannot be found. To build using the v120 build tools, either click the Proj
ect menu or right-click the solution, and then select "Update VC++ Projects..."
. Install v120 to build using the v120 build tools. [C:\Users\Home Security Sys
tem\Desktop\homebridge\node_modules\HAP-NodeJS\node_modules\ed25519\build\ed255
19.vcxproj]
PHP Code:
C:\Users\Home Security System\Desktop\homebridge\node_modules\HAP-NodeJS\node_mo
dules\srp\node_modules\bignum>node "C:\Program Files\nodejs\node_modules\npm\bin
\node-gyp-bin\\..\..\node_modules\node-gyp\bin\node-gyp.js" configure build
(node) child_process: options.customFds option is deprecated. Use options.stdio
instead.
Building the projects in this solution one at a time. To enable parallel build,
please add the "/m" switch.
tem\Desktop\homebridge\node_modules\HAP-NodeJS\node_modules\srp\node_modules\bi
gnum\build\bignum.vcxproj]
gyp ERR! build error
gyp ERR! stack Error: `msbuild` failed with exit code: 1
gyp ERR! stack at ChildProcess.onExit (C:\Program Files\nodejs\node_modules\
npm\node_modules\node-gyp\lib\build.js:267:23)
gyp ERR! stack at emitTwo (events.js:87:13)
gyp ERR! stack at ChildProcess.emit (events.js:172:7)
gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_proces
s.js:200:12)
gyp ERR! System Windows_NT 6.1.7601
gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodej
s\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "configure" "bui
ld"
gyp ERR! cwd C:\Users\Home Security System\Desktop\homebridge\node_modules\HAP-N
odeJS\node_modules\srp\node_modules\bignum
gyp ERR! node -v v4.2.1
gyp ERR! node-gyp -v v1.0.1
gyp ERR! not ok
> mdns@2.2.10 install C:\Users\Home Security System\Desktop\homebridge\node_modu
les\HAP-NodeJS\node_modules\mdns
> node-gyp rebuild
dules\mdns>node "C:\Program Files\nodejs\node_modules\npm\bin\node-gyp-bin\\..\.
.\node_modules\node-gyp\bin\node-gyp.js" rebuild
instead.
tem\Desktop\homebridge\node_modules\HAP-NodeJS\node_modules\mdns\build\dns_sd_b
indings.vcxproj]
s.js:200:12)
s\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"
gyp ERR! not ok
> ed25519@0.0.3 install C:\Users\Home Security System\Desktop\homebridge\node_mo
> node-gyp rebuild
dules\ed25519>node "C:\Program Files\nodejs\node_modules\npm\bin\node-gyp-bin\\.
.\..\node_modules\node-gyp\bin\node-gyp.js" rebuild
instead.
19.vcxproj]
s.js:200:12)
gyp ERR! not ok
npm ERR! curve25519@1.1.0 install: `node-gyp rebuild`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the curve25519@1.1.0 install script.
npm ERR! This is most likely a problem with the curve25519 package,
npm ERR! not with npm itself.
npm ERR! Tell the author that this fails on your system:
npm ERR! node-gyp rebuild
npm ERR! You can get their info via:
npm ERR! npm owner ls curve25519
npm ERR! There is likely additional logging output above.
npm ERR! System Windows_NT 6.1.7601
npm ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodej
s\\node_modules\\npm\\bin\\npm-cli.js" "install"
npm ERR! cwd C:\Users\Home Security System\Desktop\homebridge
npm ERR! node -v v4.2.1
npm ERR! npm -v 1.4.28
npm ERR! code ELIFECYCLE
npm ERR! not ok code 0
C:\Users\Home Security System\Desktop\homebridge>
Originally posted by askme
View Post
