Go Back   HomeSeer Message Board > Analog & Digital IO Device Plug-ins > Analog & Digital IO Discussion > Arduino Plugin (3P)
Arduino Plugin (3P) Discussions related to the Arduion plugin for HS3 by enigmatheatre
  #21
Old April 22nd, 2016, 08:05 AM
enigmatheatre's Avatar
enigmatheatre enigmatheatre is offline
Super Seer
Originally Posted by dhalsall View Post
Hi Greig,
I'm just starting to build a PI Linux install of HS3 and am planning to use a Mega Arduino for Analogue inputs.
I thought I had read up enough before purchasing bits... but I'm now just cluing in that Ethernet would be the only supported method of connection.
Curious if you're planning to eventually have USB connectivity supported?
Also, I had also just ordered the YUN Shield, but I'm gathering this will probably not work either?
thanks!
Dave
Hi Dave,
Sorry to hear you want to use usb but I did attempt to get this going when I first ported the plugin to Linux but there are to many limitations to make this work reliably and it would involve people manually changing files depending on there set-up. I also found the ports change on every restart so this is a big problem.
The Yun is not a standard Arduino board that will not run on the standard library's so again would take so much to change just to get one other board in there plugin that it is not worth the time and as I hope you can understand I can not support everything.
Greig.
Zwave = Z-Stick, 3xHSM100™ 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
Scripts =
Various
  #22
Old April 22nd, 2016, 10:09 AM
dhalsall dhalsall is offline
Seer Plus
Originally Posted by enigmatheatre View Post
Hi Dave,
Greig.
Absolutely, I totally understand.
Thanks for the quick reply Greig, have a great day!
Dave
Sent from my SGH-I337M using Tapatalk
  #23
Old May 5th, 2016, 12:57 AM
Seer Plus
Hello again...
I ended up purchasing a W5100 ethernet shield (Itead).
Starting playing with the plugin - and for the life of me, I couldn't get this to work.
After burning a couple of nights on this, I just discovered the issue and thought I should post here in case there's other poor sods like me poking away at such silliness....
It turns out, this shield I purchased from Robotshop.com is V1.0, and won't work directly with a Mega2650. (Even though there is no notice of this on their site, or really anywhere clearly). Also, FYI; V1.1 has one ICSP socket added, which will be compatible with more boards.
Jumpers are required to mod this to operate on the Mega... clue found in the Wiki for this particular sheild:
Iteaduino communicates with both the W5100 and SD card using the SPI bus. This is on digital pins 11, 12, and 13 on the UNO/Duemilanove and pins 50, 51, and 52 on the Mega. On both boards, pin 10 is used to select the W5100 and pin 4 for the SD card. These pins cannot be used for general I/O. On the Mega, the hardware SS pin, 53, is not used to select either the W5100 or the SD card, but it must be kept as an output.
Note that because the W5100 and SD card share the SPI bus, only one can be active at a time. If you are using both peripherals in your program, this should be taken care of by the corresponding libraries. If you're not using one of the peripherals in your program, however, you'll need to explicitly deselect it. To do this with the SD card, set pin 4 as an output and write a high to it. For the W5100, set digital pin 10 as a high output.
So, my next question is... assuming someone else has this combination... do I need to worry about setting Digital pin 4 to an output and writing it high to avoid the SD card reader from causing issues on the SPI bus?
I have now successfully got the plugin to see the board and have one Analogue sensor sending successful values.
  #24
Old May 30th, 2016, 07:03 PM
chimera chimera is offline
Pins 10 - 13 missing
I'm trialing the plugin. It looks very powerful. It's connecting well after having installed an ethernet shield and downloaded the sketch.
Pins 10-13 are not selectable from the config screen. Is there any reason for this?
  #25
Old May 30th, 2016, 07:14 PM
AllanMar AllanMar is offline
Originally Posted by chimera View Post
I'm trialing the plugin. I looks very powerful. It's connecting well after having installed an ethernet shield and downloaded the sketch.
They're used to communicate with the Ethernet shield (assuming this is not a mega).
  #26
Old May 30th, 2016, 10:05 PM
Yes I'm using the Uno. Thanks for that.
  #27
Old March 16th, 2017, 06:41 AM
ZoRaC ZoRaC is offline
Seer Plus
Does the latest beta work with NodeMCU over wifi on Linux?
  #28
Old March 16th, 2017, 06:46 AM
Super Seer
Yes this should work on Linux. I have not personally tested it but I see no reson for it not to.
Greig.
Sent from my SM-G925F using Tapatalk
Arduino Plugin Beta Version Info. enigmatheatre Arduino Plugin (3P) 9 October 29th, 2016 10:38 AM
Raspberry PI that works with the Arduino Plugin is in beta. Jakob.Sand Arduino Plugin (3P) 11 August 9th, 2016 06:01 PM
hstouch server plugin linux 3.0.0.94 beta stefxx HS3Touch Server Plug-in 1 April 13th, 2016 06:57 PM
Arduino Plugin and Linux mihaium Arduino Plugin (3P) 2 April 18th, 2015 11:04 AM
HS3 MNSandler Insteon plugin v3.0.4.10 Beta for Linux mnsandler Insteon Plug-in (Mark Sandler) 15 July 13th, 2014 09:33 PM
