Go Back   HomeSeer Message Board > Analog & Digital IO Device Plug-ins > Analog & Digital IO Discussion > Arduino Plugin (3P)
Arduino Plugin (3P) Discussions related to the Arduion plugin for HS3 by enigmatheatre
Old June 6th, 2017, 06:37 PM
langenet's Avatar
langenet langenet is offline
Sending text to LCD panel through event
So I can send text to the LCD from device manager without issue - immediate as I would expect. However, when I create an event (identical to page 9 of the user guide), 99% of the time the text is not being sent to the display.
Playing with another event, in my test, I've got a push button setup/monitored by the plugin which toggles a small relay. At this time, I'd like to update the LCD with appropriate information, but nothing gets displayed either. Are others having this problem as well?
I'm using .142 beta.
Robert
HS3PRO 3.0.0.435 as a Fire Daemon service, Windows 2016 Server Std Intel Core i5 PC HTPC Slim SFF 4GB, 120GB SSD drive, WLG800, RFXCom, TI103,NetCam, UltraNetcam3, BLBackup, CurrentCost 3P Rain8Net, MCsSprinker, HSTouch, Ademco Security plugin/AD2USB, various Oregon Scientific temp/humidity sensors, Z-Net, Zsmoke, Aeron Labs micro switches, Amazon Echo Dot, WS+, WD+ ... on and on.
Old June 7th, 2017, 08:24 AM
langenet's Avatar
As a workaround, I discovered that I can call a specific page defined/stored from the device management page. The event will call the appropriate page and display the defined text.
Robert
Old September 24th, 2017, 11:17 PM
Archcantor's Avatar
Archcantor Archcantor is offline
What I have found is I think the Send Command processes in the Event before the String is set. When I update my displays I set the Strings in one THEN section and then I use a second THEN section to perform the Sends. It's a two step process and has been working reliably for me. Not sure if there's a better way. You can't do a String update and a Send in the same THEN section. Once you use the Line number to set the string it's taken and not available for a second command in the same THEN section.
You may want to look at my postings here:
https://forums.homeseer.com/showthread.php?t=190903
____________
Rick
HS3Pro on Windows 10
Old September 25th, 2017, 09:06 AM
langenet's Avatar
Good to know.
Old September 26th, 2017, 01:05 AM
Bill Brower's Avatar
Bill Brower Bill Brower is offline
Read here: https://forums.homeseer.com/showthread.php?t=189925
~Bill
Sending keystrokes to DSC panel? dexterdom Envisalink DSC Plugin (3P) 3 October 28th, 2015 11:43 AM
Sending an email after a sensor message panel change nslmanu HS2 / HSPRO 0 August 17th, 2009 10:44 AM
Sending text-to-speech to phone basshook HomeSeer General Discussion Area 1 October 21st, 2008 12:30 AM
Sending Text to keypad MStan UltraM1G HSPI 7 August 4th, 2008 08:19 PM
sending text to keypad issue? Tom Caldwell Russound 7 December 8th, 2006 09:14 PM
