Hello Wim
Today i have added a new motion sensor, my second one.
The first i have now working for half a year without a problem.
My newly installed motion sensor adds 4 devices in HS3, motion/batt/temp and light.
The problem is that i cant change the settings from the light and temp sensor.
The default name of the lightsensor is "Hue ambient light sensor 1" and for the temp it is "Hue temperature sensor 1".
Everytime i when i want to change the device name, after some time the name is changed to default. Also when i want to change the Temperature correction, i get an error message and setting is not changed.
Also setting "Enable ledindicator" from motion sensor in Jowihuetab is not possible.
Log is in dutch :
Change name :
nov-12 13:59:40 JowiHue Extra info: 0-0-117-3
nov-12 13:59:40 JowiHue Error: (HSEvent):Error running config change:Min (4) moet kleiner dan of gelijk aan max (-1) zijn in een object Range.
Change temp correction:
nov-12 14:00:45 JowiHue Error: (ConfigDevicePost)e objectverwijzing is niet op een exemplaar van een object ingesteld.
Also there is no option in the android Hue app to change temp and light sensor names.
Latest plugin 2013 on HS3 357
Egbert
Log is in dutch :
Change name :
Egbert
