did you try the 'su root' command first
Insteon error in plugin
Mark
HS3 Pro 4.2.19.5
im not sure what to recommend hereMark
HS3 Pro 4.2.19.5
no problem. here is a workaround
shutdown the plugin from the plugin manage page
from the Tools control panel page, in the immediate box, enter the following, and press Execute
&nhs.saveinisetting("hub","GetXMLBufferInterval","1500","ins teon.ini")
if you want to try different values, just repeat this entire processMark
HS3 Pro 4.2.19.5
You must stop the plugin, run the command and then restart pluginMark
HS3 Pro 4.2.19.5
That's strange. How about this...
With the plugin disabled. Run the cmd
shutdown hs
check ini file for the [hub] section
restart hsMark
HS3 Pro 4.2.19.5
Originally posted by RichM View PostI have no way to restart it except by disconnecting the power. But still nothing in the ini file.Mark
HS3 Pro 4.2.19.5
Originally posted by IanIreland View PostI've started getting errors 2 - 3 times per day; ** An error occurred in this plug-in. The details have been written to the log file - P:\Program Files (x86)\HomeSeer HS3\Config\Insteon Error Report.Log
or the error msg at the top of the fileMark
HS3 Pro 4.2.19.5
Originally posted by DMT View PostI have been getting the same error for some time. Can't remember when it started, perhaps around the time I updated HomeSeer to 3.0.0.368 or maybe when I did a restore. Thanks for your help
or post the error msg at the top of the fileMark
HS3 Pro 4.2.19.5
