I created the Modbus IP entry, and IO get a test connection passed when Test
I created a few devices, but do not seem to be able to communicate
The Gateway is Connected
When I try to write to a coil, I get the following error in the log
Nov-13 7:27:45 PM
Modbus Error
Error in Write: The operation is not allowed on non-connected sockets.
Nov-13 7:27:45 PM
Modbus
Writing Slave: 1 Address: 100 Coil:Bool as 1
The coil is enabled, and it is not read only.
I also get an error in reading a register
Nov-13 7:30:05 PM
Modbus Error
I'm not going to poll any remaining registers on this gateway as it seems there is a communication issue.
Nov-13 7:30:05 PM
Modbus Error
Read error for Cur-Mux-In
Nov-13 7:30:05 PM
Modbus Error
Error in Read: Arithmetic operation resulted in an overflow.
Nov-13 7:30:05 PM
Modbus Error
Error in ReadValue: Arithmetic operation resulted in an overflow.
Should I be doing something else?
Is there any way to see the value of data reads in the Home view (If I am supposed to see values there, then I am not - so presumably no reads are occurring)
(I uploaded a log file, where I test the connection, and then set/unset the coil)
Nov-13 7:27:45 PM
Modbus Error
Nov-13 7:27:45 PM
Modbus
Nov-13 7:30:05 PM
Modbus Error
Nov-13 7:30:05 PM
Modbus Error
Nov-13 7:30:05 PM
Modbus Error
Nov-13 7:30:05 PM
Modbus Error
