Well, running 2.2.0.66 with 'manual entry' for lat and lon, I am getting sunrise and sundown 1 hour off. I have restarted HS, changed to fixed location, restarted again, and still off. Now back to manual entry. Any ideas and/or solutions on this?
Wrong sunup and sundown............
GuestTags: None
Guest
Clock is correct...
Rupp,
PC clock is correct and Time zone is correct (PST).
I changed from 'manual input' to 'location' (Oakland, CA).
Restarted HS between each change.
No luck.
Now back to my 'manual' input location, with HS restart.
Didn't daylight savings time just happen? (Here in Arizona we don't do daylight savings time) do you have those settings correct?Over The Hill
What Hill?
Where?
When?
I Don't Remember Any Hill
Virtualized Server 2k3 Ent X86 Guest on VMWare ESXi 4.1 with 3 SunRay thin clients as access points - HSPro 2.4.0.48 - ZTroller - ACRF2 (3 WGL 800's) - iAutomate RFID - Ledam - MLHSPlugin - Ultra1wire - RainRelay8 - TI103 - Ultramon - WAF-AB8SS - jvESS (11 zones) - Bitwise Controls BC4 - with 745 Total Devices - 550 Events - 104 scripts - 78 ZWave devices - 42 X10 devices - 76 DS10a's 3 RFXSenors and 32 Motion Sensors
Guest
patch
Rupp,
I do not recall. I recently rebuilt the computer, so I may not. I have manually adjusted the computer clock. Why would this make any difference? Doesn't HS calculate the sunrise and sunset based on the system clock and location, regardless of what reality?
Guest
time zone, etc
Rupp,
yes, time zone is correct as stated earlier. PST.
latitude and longitude are correct, to within a few hundred feet.
Guest
windoze patch
Ok, I found the xp daylight savings time patch and applied it.
HS's sunup and sundown look correct. I still don't understand what you all are doing in the programming.
