I need the z-wave lock information for each type (deadbolt or lever) of z-wave lock (Schlage and Kwikset)
I am attaching a VB.Net script that will get this information for all locks assigned in HomeSeer. What I need from you is for anyone planning to run BLLock I need you to do the following:
1. Unzip the script into your HS scripts folder
2. Go to the Control web page (/ctrl) and in the "Immediate Script Command" box type the following and click "Execute Command"
This will generate a report called Display_ZWave_Lock_Device_Info.log in your HS root folder. It will list a section for each z-wave lock it finds. It will list 4 devices for each lock it finds.
I then need you to reply back to this thread and attach the Display_ZWave_Lock_Device_Info.log file (You will need to ZIP the log before attaching as the board does not accept .log files) to the thread and indicate the lock manufacturer, model and type for each lock in the log file.
The following is an example of this information:
Lock manufacturer: Schlage or Kwikset
Lock Model: BE369 (this is the Schlage deadbolt)
Type: Deadbolt or Lever
Just make sure to list the device reference from the log of each root device lock and what the manufacturer, model and type are for each.
This will help me figure out what model of lock you are running with the plug-in.
You only need to do this if your lock information is not already listed by another user
I appreciate your help
Let me know if you have any issues.
Below is the script
&hs.RunEx "Display_ZWave_Lock_Device_Info.vb", "Main", ""
Below is the script
