Can't update pass .13
    Is it just me? I can't get pass .13 it seems to load the dll but it does not have the HSPI tacked in front. I have tried using the other screen with no luck. When I try it manually replacing the dll it says it some wrong with the class. Any one else have this trouble.
    The hspi*.dll is the license component of the plugin. The mcs*.dll is the logic component. beta updates only update the logic and not the license. HS reports the license plugin on its startup. mcsSprinklers pages will show the logic version.
      Thanks Michael
      Thank for the reply. I figured it out and was coming to replay when I read your answer.
      Do you know that when you update from the other Setup menu. 1) HomeSeer does not restart. 2) McsSprinkler has to be enabled on the >setup>Interface menu.
        I did not know about HS not restarting. Will need to look into it.
