Bob, do you have any plans for the log monitor to support .HSD files?
Any plans to support .HSD files?
no, it's a standard sqlite database, you can see what's in there by downloading sqlite3.exe from http://www.sqlite.org/download.html
then from command line:
Code:sqlite3.exe HomeSeerLog.hsd select * from Log;
Thanks Spud.
I am going to attempt to write a small plugin that monitors the HSD log file for changes, and then outputs the changed log entries to a text file.
BLLogMonitor can then be used to monitor this text based log.
I'd prefer a 'tick box' in the HS3 log options to output the log to a text file as well as the sql based file, but I am not sure that will happen.
I understand the move to sql - the new log filtering options are great but I'd still like a standard text based log as well.
This appears to be working ok.
Nothing fancy. It monitors the HSD file for changes, and if there are, it uses the hs.logGet() function to see what's new in the buffer and write this out to the TXT file.
BLLogMonitor is working with the TXT file.
Bob, it would be great if this functionality could be included in your plugin.Attached Files
Bob, it would be great if this functionality could be included in your plugin.Regards,
Rien du Pre
The Netherlands
Using:
Plugin's:
RFXCOM, mcsMQTT, Z-Wave
Originally posted by spud View Postno, it's a standard sqlite database, you can see what's in there by downloading sqlite3.exe from http://www.sqlite.org/download.html
I don`t think this is the case for HS3 ?
Code:sqlite HomeSeerLogCopy.hsd Unable to open database "HomeSeerLogCopy.hsd": file is encrypted or is not a database
Code:sqlite3 HomeSeerLogCopy.hsd SQLite version 3.8.2 2013-12-06 14:53:30 Enter ".help" for instructions Enter SQL statements terminated with a ";" sqlite>
And after this i figured out my logging did not go back far enough. So i installed log2syslog made by CrisgoLast edited by raymonvdm; June 2, 2016, 03:30 AM.
