Hi Bert,
I am having issues receiving ARC remote signals since I upgraded my plugin.
(Transceiver RfXtrx433 with firmware 71)
Yesterday I upgraded my plugin to 15.0.0.21, mainly to help me when I come to migrate to HS3, with the ability to transfer my Rfxcom devices.
After I restarted HS, my Homeeasy remote (ARC type) stopped working. I shutdown HS so I could check the receipt with Rfxmngr. Rfxmngr failed to receive status information from it, although the COM port seemed to connect ok.
I stopped RFXmngr, unplugged the USB lead to the RFXtrx, plugged it back in again and restarted Rfxmngr. All of the settings in terms of the enabled protocols seem to had reset back to defaults. I set them to what I need (OS, ARC, AD, AC) and I could see the remote signals coming in ok.
I then restarted HS and the ARC remote worked fine. But then about an hour or so later, they stopped responding again. I have left it in this state now in case there is anything you want me to check for info/debug.
I turned on level 2 debug and enabled debug for Receiver debug but nothing appears in the HS log when I press a button on the remote.
Any suggestions?
Cheers,
John
Any suggestions?
Cheers,
John
