Thing is you have to remove Mono 4.5.1 before installation of the new mono.
Not sure if you scrambled your mono installation.
Try deleting new mono first.
sudo apt-get remove mono-complete
This is the way that I deleted it old mono 4.5. Try this next. I think this will delete anything related to mono which is what you want to do
before installing new mono. Make sure HomeSeer is not running when you are doing this stuff.
sudo apt-get purge libmono* cli-common mono-runtime or mono-complete
then after and before installing mono 5.4 check to make sure that mono 4.5 is gone by
doing a mono -V.
Here is what it looks like with most current version of mono.
Pine64:~# mono -V
Mono JIT compiler version 5.4.1.6 (tarball Wed Nov 8 21:20:16 UTC 2017)
Copyright (C) 2002-2014 Novell, Inc, Xamarin Inc and Contributors. www.mono-project.com
Also if you have updated from mono 3.28 to mono 5.4 check you event triggers as they might not be there.
For HomeSeer 3 you only need to install:
1 - sudo apt-get install mono-complete
2 - sudo apt-get install mono-vbnc
doing a mono -V.
Pine64:~# mono -V
