I have experienced an unusual issue with including an Aeotec Nano ZW-111-B AU that every time it is included, it is automatically removed. I have attempted this a number of time and the outcome is exactly the same. Z-wave 3.0.1.150
HomeSeer Version: HS3 Pro Edition 3.0.0.368 (Windows)
HomeSeer: Is Registered
Operating System: Microsoft Windows 10 Pro - Work Station
OS Version: 10.0.15063 Service Pack: 0.0
System Uptime: 0 Days 3 Hours 9 Minutes 46 Seconds
Network Adapter: Adapter -> Intel(R) 82579V Gigabit Network Connection IP:
Network Adapter: HomeSeer Adapter -> Loopback Address (localhost) IP: 127.0.0.1
Web Server Port/SSL Port: 80 / 443
Number of Devices: 837
Number of Events: 83
Number of unique event scripts used: 1
Plug-Ins Enabled: Z-Wave:,Sonos:,RFXCOM:,ImperiHome:,HSBuddy:,EnvisaLink:,DoorBi rd:,EasyTrigger:
Processor Type and Speed: Intel64 Family 6 Model 42 Stepping 7 at 3.17 GHz
Modules/Threads: 146 Modules, 115 Threads
Available Threads: 800
System Processes/Load: 188 Processes, 6% Load
Free / Total Physical Memory: 4.62 GBytes / 7.98 GBytes (58% free)
Free / Total Virtual Memory: 5.08 GBytes / 9.23 GBytes (55% free)
HomeSeer Memory Used: 127 Mbytes
Plug-In Memory Used: 8 EXE Plug-Ins using 318 Mbytes
Oct-22 16:35:24 Z-Wave DEVICE RESET LOCALLY: Node removal process completed. (Node 124) Oct-22 16:35:23 Z-Wave 7 out of 8 Child devices of node 124 were created successfully. Oct-22 16:35:23 Z-Wave Setting a polling interval of 21 Minutes, 56 Seconds on device Switch Multilevel Oct-22 16:35:23 Z-Wave Setting a polling interval of 20 Minutes, 54 Seconds on device Switch Binary Oct-22 16:35:22 Z-Wave Setting a polling interval of 20 Minutes, 52 Seconds on device Notification Oct-22 16:35:22 Z-Wave Setting a polling interval of 20 Minutes, 50 Seconds on device Amperes Oct-22 16:35:21 Z-Wave Setting a polling interval of 20 Minutes, 48 Seconds on device Volts Oct-22 16:35:21 Z-Wave Setting a polling interval of 20 Minutes, 46 Seconds on device Watts Oct-22 16:35:21 Z-Wave Adding Watts as an Energy tracking device. Oct-22 16:35:21 Z-Wave DEVICE RESET LOCALLY: Node removal process completed. (Node 124) Oct-22 16:35:21 Z-Wave Node 124 was removed successfully. Oct-22 16:35:20 Z-Wave Adding Node 124 Z-Wave kW Hours as an Energy tracking device. Oct-22 16:35:20 Z-Wave Home: Controller firmware version: 1.0 Oct-22 16:35:20 Z-Wave Home: Controller Manufacturer: Aeon Labs, ID=0x5A, Type=0x3 Oct-22 16:35:15 Z-Wave Getting association information for Node 124 Z-Wave Aeon Labs Switch Multilevel Oct-22 16:35:15 Z-Wave Warning Failed to set the current date and day of the week using the CLOCK command class on Node 124 Z-Wave Aeon Labs Switch Multilevel Oct-22 16:35:15 Z-Wave Warning Error setting CLOCK for node 124, Send failed. Oct-22 16:35:02 Z-Wave Successfully removed node 124 from interface Home. Oct-22 16:35:02 Z-Wave Home: Node 124 was removed from interface Home. Oct-22 16:34:41 Z-Wave Root Node Device Node 124 Z-Wave Aeon Labs Switch Multilevel was created for node 124 on network F6EDF82A Oct-22 16:34:29 Z-Wave Warning Could not get the SWITCH command class version for node 124 . Oct-22 16:33:40 Z-Wave Removing node 124 from interface Home Oct-22 16:33:37 Z-Wave Warning Device Reset Locally Notification received for node 124 - NODE IS BEING REMOVED FROM THE SYSTEM. Oct-22 16:33:37 Z-Wave Node 124 Meter is Supported for Electric_meter, Type ELECTRIC_A, Scale is INSTANT Oct-22 16:33:37 Z-Wave Node 124 Meter is Supported for Electric_meter, Type ELECTRIC_V, Scale is INSTANT Oct-22 16:33:37 Z-Wave Node 124 Meter is Supported for Electric_meter, Type ELECTRIC_W, Scale is INSTANT Oct-22 16:33:37 Z-Wave Node 124 Meter is Supported for Electric_meter, Type ELECTRIC_kWh, Scale is ACCUMULATED Oct-22 16:33:36 Z-Wave Node 124 is a Z-Wave Plus node. Retrieving ZWPlus Info... Oct-22 16:33:36 Z-Wave Node 124 is Z-Wave version: Lib: 4.38 App: 1.2 Oct-22 16:33:35 Z-Wave Node: 124 Controls Class(es): HAIL Oct-22 16:33:35 Z-Wave Node: 124 Supports Class(es): ZWAVEPLUS_INFO, VERSION_V2, MANUFACTURER_SPECIFIC_V2, DEVICE_RESET_LOCALLY, POWERLEVEL, ASSOCIATION_V2, ASSOCIATION_GRP_INFO_V2, SWITCH_BINARY, SWITCH_MULTILEVEL_V3, SWITCH_ALL, METER_V3, CONFIGURATION_V4, CLOCK, NOTIFICATION_V6, SCENE_ACTUATOR_CONF, SCENE_ACTIVATION, FIRMWARE_UPDATE_MD_V2 Oct-22 16:33:35 Z-Wave Z-Wave manufacturer information for node 124, ID: 134=86H (Aeon Labs), Type: 515=203H, ID: 111=6FH Oct-22 16:33:35 Z-Wave Checking if we can reach node 124 Oct-22 16:33:35 Z-Wave Getting class information for node 124... Oct-22 16:33:35 Z-Wave Device synchronization needs to get Z-Wave class information for one node. Oct-22 16:33:35 Z-Wave Synchronize nodes finished. Number of device nodes to be created/added = 1 Oct-22 16:33:34 Z-Wave Done. Node 124 Added
