Hi...
I am trying to install the HS Commander Plugin and for some reason, after installing the correct file in the Homeseer directory, under the view-options---interfaces---plug ins drop down list in Homeseer, the HS Commander plug in does not appear. The other plug ins appear - but its crazy - this plug in will not appear so I cannot configure same.
Any suggestions? Is this a HS Commander plug in problem or has anyone had this problem with any other plug in where for some reason it wont appear? I started and stopped Homeseer, rebooted, nothing works. So I cannot use the plug in.
I am trying to run an executable batch file from the desktop of another PC on my home network that will command the PC with Homeseer installed.
- Adam
- Adam
