Find my iPhone plugin for HS3
    #91
    Yup
      #92
      Thanks. Just need a bit of guidance
      Steve
        #93
        Can anybody help me resolve this error in log:
        20:06:44,990 Common.BaseHSPI [5 ] INFO - InitIO using COM1
        20:06:44,993 Common.BaseHSPI [5 ] INFO - Initializing
        20:06:45,037 _RSFindMyDevice.HSPI [5 ] DEBUG - Downloading http://maps.googleapis.com/maps/api/...e:tiny%7C0%2C0 to C:\Program Files (x86)\HomeSeer HS3\html\HSPI_RSFindMyDevice\Stamp_1.jpg
        20:06:45,066 s.FindMyPhoneService [4 ] DEBUG - Redirected to05-fmipmobile.icloud.com
        20:06:45,125 _RSFindMyDevice.HSPI [5 ] ERROR - System.Net.WebException: The remote server returned an error: (403) Forbidden.
        at System.Net.WebClient.DownloadFile(Uri address, String fileName)
        at System.Net.WebClient.DownloadFile(String address, String fileName)
        at HSPI_RSFindMyDevice.HSPI.GetDeviceString(Device d)
        20:06:45,175 _RSFindMyDevice.HSPI [5 ] DEBUG - Downloading [URL]
        Thank you
        Greg Mack
          #94
          Thank you
          Greg Mack
          It looks like your username or password is incorrect.
          Jason
            #95
            My iTunes user/password is correct, because it connect correct.
            Do I need a Google user/ password also?
            Thank you
            Greg
              #96
              I am still getting this error in my log file. I am connect ok. (win 8)
              System.Net.WebException: The remote server returned an error: (403) Forbidden. at System.Net.WebClient.DownloadFile(Uri address, String fileName) at System.Net.WebClient.DownloadFile(String address, String fileName) at HSPI_RSFindMyDevice.HSPI.GetDeviceString(Device d)
              Thank
              Greg
                #97
                Thank
                Greg
                Please attach a log so I can troubleshoot.
                Jason
                  #98
                  I had to create a new api key and started to work.
                  Maybe you can give more information on how to add a new api key.
                  Greg
                    #99
                    Originally posted by pcp View Post
                    Looks interesting! Can you disable the auto update by setting update rate in the account to 0 (and us events to refresh as needed)?
                    I haven't tried setting it to zero, but I did change it to 4 hours. And I have an event that updates devices when one of our cars leaves or arrives home and whenever the HS Touch screen with GPS info is opened.
                    Works quite well.
                      TRIAL EXPIRED
                      Where do I purchase this plug-in? It's not available in the HS Store.
                        Me too, mines only a few days from expiry. I also notice that one of the reverse geocache now fails to update!! How do I get this working again. If I delete the device will the PI automatically re create it ?
                        Steve
                          Originally posted by jbbtex View Post
                          TRIAL EXPIRED
                          Same here... Since I changed my decimals from comma to dot plugin is working fine. Hope to be able to buy it.
                            I've asked HS to add it to the downloader several times. I have sent them everything and submitted the form.
                            I have 3 other plugin's to add and I'm losing faith in getting them in the system.
                            Sorry everyone.
                            Jason
                              Sorry everyone.
                              Jason
                              This is one of the few plug ins that I would use if it were available and one reason I am monitoring the forum. Not sure why its not being added.
                                Sorry everyone.
                                Jason
                                I assume you sent it to the update remain.... Several month ago had a similar issue and sent an email to Rich which helped resolving it.
