Initial questions, ideas
    Hi Mikemack, very interesting plugin!
    1. Is it possible to create an automated 'dimming schedule' with this plugin?
    I'd like to create a schedule that tracks the sunset/sunrise and in between (with approx 1hr resolution, except during sunset/sunrise is much finer) to set the dimming level of LED strips that has both Cool White (6000k) and Warm white (3000k). The idea is to make a smooth transition from cool white in the daytime to warm white in the evenings, by shifting the dimming level slightly every hour (every minute during sunset/sunrise transition).
    ie:
    2pm: Cool white 90%, Warm White 10%
    3pm: CW 80%, WW 20%
    4pm: CW 70%, WW 30%
    5pm: CW 60%, WW 40%
    etc
    Ideally the right dim level is called up upon activation (events), but also automaticallly during scheduled shifts (ie: 14:59 to 15:00, etc)
    2. Feature request: make a graphical scheduler widget like EasyTrigger's
    http://board.homeseer.com/showthread.php?t=173836
    ps: I think you should mention/market the 'multi standard' nature of this plugin...
    HW: HS3 w/ Win8.1 on ASRock C2550d4i. Digi AnywhereUSB, Hubport, Edgeport, UZB, Z-trollers, PLCBUS, SONOS, GC-100, iTach IP2SL, WF2IR, IP2IR, RFXtrx433, Harmony Hubs, Hue, Ademco Vista 128BP, NetAtmo, NetAtmo Welcome
    Google Search for HomeSeer Forum
    ie:
    3pm: CW 80%, WW 20%
    4pm: CW 70%, WW 30%
    5pm: CW 60%, WW 40%
    etc
    Interesting.. Out of the box it would not support it, but it would be possible to add a 'Animated dim control' where triggering it would cause a progression from one scene 'profile's' dim slider position to another. You could then trigger it from HS using the built-in sunset calculation.
    If I added, would you be interested in doing some beta testing
    I'll look into that.. Tweaking web UI is not the ideal way for me to spend time.. :-).. Since it's only for configuration I will probably keep this one down at the lower end of the priority list..
    Good point; I'll update to be a little more specific; actually it was hard for me to adequately describe what this plugin does, so thank you for the feedback!
    -Mike
      Ok. Will this lessen the number of events I have to create and edit manually?
      I will have 6 CW+WW LED zones and about 6 Phillip Hue zones; with gradual change throughout the day, if they have to be managed by separate events is about 12 zones x 10 steps = 120 events ;(
      For sure!!
      Cool. Those with EasyTrigger access can probably make use of that plugin to manage the schedule of your scene plugin too.
        So, here is what I am thinking:
        I can create a HS device for a timed dim sequence. You can set the Initial slider value, step, max, and step time. When you trigger the device it will start the sequence. It will obey the 'cancel timer on member device change option' so that it stops the sequence if a user action changes the value while the time sequence is operating.
        I will also need to enable an option to allow the dim slider to be active all the time for a specific profile. Currently since a scene (group of devices) can have multiple profiles, each with a different dim scaling that share the same slider; the slider is only enabled when the scene profile is active.
        How does that sound?
        -Mike
          So if it's interrupted, it will resume later where its left off/at the correct scheduled dimming level?
          I think it sounds good
            I will make an option to enable or disable aborting the "Animated dim trigger" (what I am calling this) if a member device changes state; if set it will just abort. if not set it will continue (I think what you want)
            I'll see if I can have a test version of this in a few days
              In my mind, Ideally the dimming level is like a schedule that can be looked up for each hour/minute (well, calculated from daily sunset/sunrise); and this table will be looked upon when a light is turned on due to an event trigger, or due to a time change that prompts a shift in the dimming level.
              ie:
              1). Device is turned on (manually from a switch or event): looks up what's the current dimming level supposed to be from this table, and applies it.
              2). Device is already on and the time changes from 15:59 to 16:00; according to the table, dimming level of this light should decrease to 55%, applies that.
              Apologies if that's not clear.. english isn't my first language ;(
                ie:
                That is clear; but will not map to the way this plugin works..
                I can emulate similar behavior by using the built in dimmer control. Here is how it will work..
                You create a scene/profile, add devices, and using the advanced dimming control create a custom dim profile - In that profile you can specify 101 values corresponding to slider positions 0-100 inclusive; one for each time delta you want to control. You will set the (new) option to make this profile the 'default dimming device' meaning that it will always respond to dim events. Now, you have a slider that you can control that will control the individual devices based on each step of the slider.
                Now; the new function I will add is something to 'animate' the slider moving from one point to another. You can kick this off using the sunset/sunrise triggers from within HS.
                Additional note: Using it in this way it really does not matter what values you set for the scene profile; I would suggest setting to all max and naming the profile "all on"
                I think this should do what you want, but just in a little maybe 'strange' way; just due to the way I can incorporate the function into this plugin.
                As a nice side-effect, the slider position will change so you can track it with some gauge or display using HSTouch if you want..
                -Mike
                  -Mike
                  Cool Looking forward to it!
                  I'd imagine a dimming schedule like this can also be applied to volume level off sound systems (Sonos, squeezebox, etc) and all the dimmable light tech (zwave, upb, plcbus, x10, Hue, MiLight, etc) to create gentle scene shifts.
                    Hi Leo,
                    I have a debug version ready to test.. no docs yet, so try to figure it out until I get to writing it up.. :-)
                    Place the attached file in the HS dir and update the plugin.
                    --Updated-- I posted the wrong file..
                    Mike
                      Hi Leo,
                      Mike
                      Cool!
                      Q: if an animated trigger is being executed and interrupted halfway, it will restart from the beginning, if we use the same event trigger right?
                        I just posted an update, so using the same updater_override.txt do an update -- there was a bug that would cause it to not work at all if you had previous scenes setup.. Fixed now..
                        Cool!
                        It would restart from the beginning. There is only a concept of canceled.. If you create more than one starting the second will cancel the first. Also issuing an 'all off' scene command will cancel it.
                        -Mike
                          Had some time to do some testing - feature now in release version
                            Amazing Work Mike.
                            It's been along time that I have wanted something like this. As Leo pointed ut it would take countless events to even start to mimic what your plugin self creates.
                            Way to go.
                            Charlie.
                            HSPro: 3.0.0.194
                            PL: Insteon PLM 3.0.5.20,Insteon Thermostat 3.0.1.1 , UltraM1G, RainRelay8, UltraECM3, UltraPioneerAVR3, BLBackup, weatherXML, Jon00 Network & PC Monitor
                            HW : Win 7 64bit, Intel i7-2600, 16 GB DDR3 Ram, 60 Plus Insteon Dual Band Devices, Rain8 Pro2, Elk M1 Gold, Brueltech GreenEye.
                              Thanks for the kind words.. I hope you find it useful!
