HS-WD100+ Setting Ramp Rate via parameter
    Hello-
    I am having trouble setting ramp timers via parameter. I ran across a thread today that Rich had posted in regarding setting ramp rate parameters via event here. Here is an excerpt:
    local control dim rate (dimmer only)
    9 = step (1-99)
    10 = timer (1-255)
    remote control dim rate (dimmer only)
    7 = step (1-99)
    8 = timer (1-255)
    I set up an event to change parameter 8 (remote timer) and it did nothing. I went into the z-wave tab for the dimmer and tried setting parameters 8 and 10 manually... after hitting set, the actual timer value stayed the same, and the previous value replaced my requested value in the Set Configuration Parameters value window. In the image below, I tried to set parameter 10 to 5, but after hitting the Set button, the value reverted to the current setting.
    If I tried to set parameter 7 or 9 (steps), it worked as I would expect. But 8 and 10 (timers) are a no-go. Any ideas?
    Jon
Name:	Capture Z-Wave Ramp Rate.jpg
    I need to add that I'm running v5.14 firmware on the dimmers that I tested and Z-wave plugin v3.0.1.130.
    Current Date/Time: 12/20/2017 10:39:04 PM
    HomeSeer Version: HS3 ZEE S2 Edition 3.0.0.368
    Linux version: Linux HomeTrollerZeeS2V2 4.1.19-v7+ #858 SMP Tue Mar 15 15:56:00 GMT 2016 armv7l GNU/Linux System Uptime: 0 Days 5 Hours 16 Minutes 19 Seconds
    IP Address: 192.168.1.131
    Number of Devices: 174
    Number of Events: 87
    Available Threads: 379
    Enabled Plug-Ins
    3.0.0.20: Ecobee
    3.0.0.39: EnvisaLink
    3.0.1.130: Z-Wave
      Does anyone have any ideas? I cannot set parameter #8 (timer). It is rebuffing my efforts on both 5.14 and 5.16 dimmers. Whenever I hit the set button, nothing happens. However, I can set parameter #7 (step) using the parameter set dialogue. I tried running the z-wave beta plugin (3.0.1.179) but that did not work either. I'm having trouble updating the firmware on my switches, so for now I'm stuck.
      What am I doing wrong? It's probably something simple that I'm missing.
