I went to install a couple of insteon switches today. I also activated insteon in some in line lincs that had been x10 only. Somehow I have tripped and fallen down.
The original items seem to work. However I had some problem with the two newer Keypadlincs. I got updates from the pads but because I had moved them I wanted to update the address database. That wouldn't work, it wouldn't find the links. So I decided to delete the keypad lincs and re add:
13:6B:7C
13:6A:8C
When I try to add them I get:
The device properites could not be read. Communication failure. The Device was not added.
One other anomaly.. I use the scripting feature to talk to my ezfloras. There is now a message between each transaction with the controller:
Script Insteon_ExtDevSupport.vb is currently running, waiting for it complete before its run again
I did update the version of plugin yesterday, it may be from that
I want to get these two switches back. Log attached
Paul
13:6B:7C
13:6A:8C
Paul
