Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Hardware > HS-MS100+ Motion Sensor
HS-MS100+ Motion Sensor Forum for HomeSeer HS-MS100+ Motion Sensor
  #41
Old December 27th, 2017, 11:23 PM
macromark's Avatar
macromark macromark is offline
HomeSeer Technologies
Originally Posted by julez View Post
So what kind of range and spread are we looking at for the motion sensing?
I was just about ready to pull the trigger on some Zooz sensors, but the line power intrigues me. Also what kind of power adapter does it require? I'd assume I could just use the same sort of adapter that I have for a Pi3?
A Pi3 power adapter should work just fine.
  #42
Old January 10th, 2018, 07:18 PM
thewizardofoz's Avatar
thewizardofoz thewizardofoz is offline
How does this sensor detect motion?
I have an Aeon Labs version that uses light and heat for motion detection. the problem is that a light turning on will trigger a motion event.
I also look forward to an outdoor version.
  #43
Old January 11th, 2018, 02:59 PM
Conrad_Turbo Conrad_Turbo is offline
I suspect it uses a PIR very similiar to this:
https://www.aliexpress.com/item/Free...ceBeautifyAB=0
Work great as I use it tied to an arduino with the arduino plugin to detect my cat trying to eat our house plants. It's not a pet immune sensor, I don't see anything about this new HS device if it's pet immune or not. Might be important to some.
  #44
Old January 15th, 2018, 10:09 AM
macromark's Avatar
it uses an infrared sensor.
  #45
Old January 18th, 2018, 12:26 AM
julez julez is offline
I'm actually using a pair of these in my garage right now. We've had a pretty nasty cold spell where the garage was closer to -15C and they continued to work without any issue even though it says 0-40C. I expect the temperature range is probably conservative.
I do have a coupe questions about them.
1. Since they an be line powered, is there any way to make them so they can always in a listening node state?
2. What is the sensitivity adjustment actually adjusting? Is it the object size it's seeing move? Or the speed of the movement?
3. One observation, seems like it takes roughly 1 second for it to trigger motion. Which is actually pretty good considering other sensors I've worked with sometimes are 4-5 seconds. Are there any adjustments that can be made to make it faster?
  #46
Old January 18th, 2018, 09:46 AM
cheeryfool's Avatar
cheeryfool cheeryfool is online now
Super Seer
Usually for point 1, you have to exclude the device and then re-add it when it's being externally powered.
cheeryfool
  #47
Old January 18th, 2018, 10:51 AM
macromark's Avatar
  1. Yes, you can set the motion timeout to something very small like 10 seconds
  2. The refers to the sensitivity of IR. Typically, this translates to increasing the range (distance)
  3. No
  #48
Old January 18th, 2018, 11:06 AM
  3. No
Ha! I was going to mention range also in number 2.
This is perfect! Thanks!
Can't wait to see the Outdoor units.
So just a follow-up on 1 with the motion timeout. If I have HS3 try to communicate with the sensor with that low of a timeout, it's essentially listening and should respond then?
Just doing some more configuration yesterday evening I had it set to 60sec for the timeout and at that point I still had to tap the button 4 times to be able to communicate with the sensor in order to see and change the configuration settings or to optimize it.
To follow-up on what cheeryfool said above. Is there any difference in adopting the sensor on battery vs line power?
  #49
Old January 18th, 2018, 11:37 AM
macromark's Avatar
If you include the unit while on line power, it will function as a ROUTING SLAVE ("repeater"), you won't need to wake it to get into the settings and you can set the motion timeout as low as "0" which will make it extremely responsive.
  #50
Old January 18th, 2018, 01:09 PM
Thanks, this is extremely useful information!
  #51
Old January 19th, 2018, 02:07 PM
So I tried this. Completely removed the battery before the secure inclusion.
It comes up as Enhanced Routing Slave, but if I test connectivity I get a failed to reach node.
https://www.dropbox.com/s/nvjlraiatf...pture.JPG?dl=0
  #52
Old January 19th, 2018, 04:32 PM
Stuart Stuart is offline
I'm also seeing the same behavior. The unit only responds to motion otherwise I get the failed to reach node.
Stuart
Auditing node 73 (Node 73 Z-Wave HomeSeer Motion Sensor) ...
HomeSeer was able to send a frame to the node.
HomeSeer cannot test two-way communication with the node because it is a non-listening node.
This was included to the system on a power supply and the battery was removed from the system prior to inclusion and remains out of the unit.
  #53
Old January 19th, 2018, 04:45 PM
macromark's Avatar
Stuart
Not an issue for me. What version of the Z-Wave plug-in are you using? And... did you try optimizing the node?
  #54
Old January 19th, 2018, 05:04 PM
just woke up the unit
optimized
got this after it optimized after wating 15 seconds
Failed to reach node 73 (Node 73 Z-Wave HomeSeer Motion Sensor)
zwave 3.0.1.185 Hs3 3.0.0.402
HomeSeer Tech Version: 1.1 firmware
Stuart
  #55
Old January 19th, 2018, 06:36 PM
macromark's Avatar
optimized
Stuart
If it's on line power when you include it, there should be no need to wake it up. You should be able to click on "Settings" on the Z-Wave tab and all settings will display. Try including it again but this time bring the sensor close to the controller first, then put it on line power and exclude it, them include it again. Then check the settings and do a connectivity test. Once that's working properly, reposition it, plug it in and optimize it. Everything should be good then.
  #56
3.0.1.184
I was pretty sure I did a full optimize. I'll double check when I get home.
Last edited by julez; January 20th, 2018 at 01:01 PM. Reason: I said 173... I'm using 184.
  #57
Old January 19th, 2018, 06:50 PM
excluded and included only on power. 2 feet from the znet. same results.
The unit behaves the same. I took the battery out the first day I got the unit.
Stuart
  #58
Old January 20th, 2018, 01:19 PM
Ah I think I figured it out.
I had not changed the wake-up interval away from 12hrs.
Adjusting this setting to 1 second basically got it taken care of.
But pairing it on line power vs battery didn't seem to make any difference.
I also tried secure and non-secure on line power.
So if line power inclusion is supposed to change the wake-up interval, I don't think it does currently.
  #59
Old January 20th, 2018, 02:40 PM
Actually nope I was wrong, it didn't help after all. I don't think I waited long enough before.
  #60
Old January 20th, 2018, 02:58 PM
So after extensive testing it gets worse. I cannot get this to continuously listen. I have been able to change all the settings except when I get to time. The time change window will not bring up the numbers if you first click on days. I have to choose another time first then clicking on days the numbers appear. However I am unable to set the time for any amount of minutes or seconds. I have tired this both on chrome and firefox. I can select 1 second and then after clicking on the set button I find that it never updates in the device, yet if I go back to change it, the seconds are still selected in the time change choice box.
Stuart
Fibaro motion sensor gen 5 generate motion when no motion tonlof HomeSeer Z-Wave Plug-in 23 June 30th, 2017 12:32 AM
Fibaro motion sensor gen 5 unreliable motion sensor and event trigger mroovers HomeSeer Z-Wave Plug-in 13 December 29th, 2016 01:16 PM
DHS-ZW-SNMT-01 Motion Sensor won't detect motion - Solution! Conchordian Lighting & Primary Technology Discussion 4 January 5th, 2013 03:10 AM
Motion Sensor & Dusk/Dawn Sensor Script Package Discussion Jim Doolittle Script & Plug-In Library Discussion 262 October 31st, 2002 08:06 PM
A bug? Motion Sensor & Dusk/Dawn Sensor Script Package Version 4.30d bmms Script & Plug-In Library Discussion 7 March 22nd, 2002 09:15 AM
