Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Hardware > HS-MS100+ Motion Sensor
HS-MS100+ Motion Sensor Forum for HomeSeer HS-MS100+ Motion Sensor
Old January 10th, 2018, 09:51 PM
gashuffer gashuffer is offline
Viewer
SmartThings integration
Hi all, I bought some Homeseer switches and sensors to go with a SmartThings hub. The switches paired after a long-assed time but they're on the network and working.
Not so with the HS-MS100+ motion sensors. They're on but SmartThings recognizes them as "Z-Wave Door/Window Sensor." And according to the system, they're closed.
What do I do to make these things work properly?
Thank you,
chris
Old January 10th, 2018, 11:15 PM
Rupp's Avatar
Rupp Rupp is offline
I believe you would need to check with SmartThings to see if they've tested these and if these are compatible.
-Rupp
SmartThings hub not detecting WD100+ Mako HomeSeer Wall Dimmers & Switches 5 October 9th, 2017 06:50 PM
Run Command like SmartThings? ramshaklez HomeSeer Amazon Echo Connected Home API 3 April 4th, 2016 12:27 AM
Run Command like SmartThings? ramshaklez HomeSeer Amazon Echo Skill 2 April 2nd, 2016 12:55 PM
SmartThings + BMW - January 5, 2016 Pete Off Topic 0 January 6th, 2016 10:56 AM
Samsung Buys SmartThings GatorEye HomeSeer General Discussion Area 12 October 12th, 2014 10:55 AM
