Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Hardware > HS-MS100+ Motion Sensor
HS-MS100+ Motion Sensor Forum for HomeSeer HS-MS100+ Motion Sensor
Old February 25th, 2018, 03:54 PM
jeff.texasfleet@yahoo.com jeff.texasfleet@yahoo.com is offline
Sending a Wake Up Command
How do I send a Wake up Command to this Device??
Old March 1st, 2018, 11:48 PM
flaplante@gmail.com flaplante@gmail.com is offline
Hi... i'm having the same question. I'm trying to change settings of the device, but it keeps telling me that the device is asleep.
Please wake the device before hitting 'Ready'. If the device is a asleep, the command will be sent when it wakes.
I've been able to do it only 1 time on my first device and I just cant say how I did it... pure luck maybe when the device wakeup for a second.
What's the trick to wakeup the device to load current settings and set a new value to one of the parameters ?
Waiting for a reply asap...
Old March 2nd, 2018, 12:20 AM
mbirrell mbirrell is offline
When you set up the device it should give you an option on how often the device wakes up. If the device wakes up often then your battery life will suffer. Really you need to set the wake up interval to a time period that suits you rather than sending the device commands to get a reading... What sort of device is it? and what is it's model number?
Old March 2nd, 2018, 06:39 AM
Stuart Stuart is offline
To wake up the sensor press the button quickly 4 times and you'll see the flashing blue light.
Stuart
Old March 4th, 2018, 10:06 AM
Stuart
Thanks Stuart, it works, when you press the button quickly 4 times, the device stay awake for a few second giving the time to receive the new parameters.
This trick should be written in the device documentation...
Have a nice day!
Mystery Z-Wave Nodes Sending Wake-Up Notifications Wazoo HS3 / HS3PRO Discussion 8 August 29th, 2017 06:26 PM
Can I queue a Z-wave command or send on device wake-up? PtHomeAutomation HomeSeer Z-Wave Plug-in 10 March 25th, 2017 06:59 AM
Node sending wake up notification but... Rvtravlr HomeSeer Z-Wave Plug-in 0 July 6th, 2016 10:21 PM
Wake up screen on HST-IWAR7 through HomeSeer Command GlennWo HST-IW07 Touchscreen 1 November 24th, 2012 02:22 AM
wake up command? collegeboyslive HomeSeer General Discussion Area 4 May 19th, 2004 04:06 PM
