Using HD-WD200+ with Phillip's Hue Lights
    I was curious about using the WD200 with some Phillip's hue lights and making sure the switch isn't actually cutting power to the lights but sending an off command via the Hue bridge.
    I had seen someone recommend wiring the load and line wires together for a similar set up with a GE dimmer. Would that work with the WD200? I'm guessing not due to the power requirements of the small LEDs. If I followed this route I could set up a scene which just mirrors the switch state with the hue lights and allow full control without cutting power when I want to turn them off.
    Any other suggestions to get a optimal set up?
