CT32 - Sensor Type Information Missing Error
    I have had this CT32 thermostat for years now and works well. Since around a restart at the end of February
    Feb-28 18:55:19 Startup HomeSeer version 3.0.0.298 Edition: HS3 Standard Starting Now
    there has been a persistent issue in the log (amber in colour) being reported:
    Apr-01 09:07:44 Z-Wave Warning Z-Wave Multilevel Sensor device Main Dining Room CT32 - Temperature is missing Sensor Type information - cannot update sensor status.
    Tracing back in the log I find:
    Feb-28 19:07:14 Z-Wave Warning Node 17, EndPoint=-1 Multilevel Sensor Report was not received (B) - the child device will NOT be configured properly.
    On the very next poll this error starts:
    Feb-28 19:18:06 Z-Wave Warning Z-Wave Multilevel Sensor device Main Dining Room CT32 - Temperature is missing Sensor Type information - cannot update sensor status.
    I did a rescan this morning and appears all is reconfigured correctly:
    Apr-01 08:58:50 Z-Wave Device: Main Dining Room CT32 - Temperature Set to 21.1111111111111 (C)
    Apr-01 08:58:49 Z-Wave 7 out of 7 Child devices of node 17 were created successfully.
    Apr-01 08:58:49 Z-Wave Setting a polling interval of 21 Minutes, 38 Seconds on device Main Dining Room CT32 - Temperature
    Apr-01 08:58:49 Z-Wave Node 17 Supports Thermostat Setpoint CC and supports these setpoints: Heating 1, Cooling 1
    Apr-01 08:58:49 Z-Wave Node 17 Supports Thermostat Mode CC and supports these modes: Off, Heat, Cool
    Apr-01 08:58:49 Z-Wave Node 17 Supports Thermostat Fan Mode CC and supports these modes: Auto, On
    Apr-01 08:58:49 Z-Wave Device: Main Dining Room CT32 - Temperature Set to 21.1111111111111 (C)
    Apr-01 08:58:48 Z-Wave Device: Node 20 Z-Wave MS002 - Test Motion Sensor Set to Off/Closed/No Motion
    Apr-01 08:58:48 Z-Wave Device: Node 20 Z-Wave Home Security Set to NOTIFICATION for type Home Security, Event: No Event
    Apr-01 08:58:48 Z-Wave Node 17 is Z-Wave version: Lib: 2.78 App: 7.4
    Apr-01 08:58:47 Z-Wave Node: 17 Supports Class(es): BASIC, INDICATOR, MANUFACTURER_SPECIFIC, SENSOR_MULTILEVEL_V2, THERMOSTAT_MODE_V3, THERMOSTAT_FAN_MODE, THERMOSTAT_SETPOINT_V3, THERMOSTAT_OPERATING_STATE_V2, VERSION_V2, CONFIGURATION, BATTERY, PROPRIETARY
    Apr-01 08:58:47 Z-Wave Syncing Z-Wave nodes with device list...
    Apr-01 08:58:47 Z-Wave Found 31 Z-Wave nodes
    Apr-01 08:58:47 Z-Wave Getting Z-Wave node list for network C8E9XXXX...
    After a couple polls since the recscan the error is reported:
    Apr-01 09:29:02 Z-Wave Warning Z-Wave Multilevel Sensor device Main Dining Room CT32 - Temperature is missing Sensor Type information - cannot update sensor status.
    So my questions are:
    1. Is this a nuisance error? I am still receiving temperature updates and I can control through my automated events which is what I care about.
    2. What is being polled/requested every 22 minutes from the sensor?
    3. Has any code update in version .298 broken something with this thermostat?
    Thanks for any guidance.
    Current config info:
    Current Date/Time: 2017-04-01 09:44:20
    HomeSeer Version: HS3 Standard Edition 3.0.0.313
    Operating System: Microsoft Windows 10 Home - Work Station
    System Uptime: 6 Days 1 Hour 5 Minutes 25 Seconds
    IP Address: 192.168.0.XXX
    Number of Devices: 182
    Number of Events: 21
    Available Threads: 400
    Enabled Plug-Ins
    3.0.0.15: EnvCan
    3.0.0.68: HSTouch Server
    1.0.16323.357: MyQ
    3.0.1.87: Z-Wave
    I would upgrade the z-wave plugin to something newer than version .93 and then rescan again. You may need to delete that child device and then rescan. There were some bugs in .87 related to child devices that were fixed in .93 as far as I recall.
    Cheers
    Al
      Thanks for the suggestion. I updated to beta .110 but the problem persists. I also deleted the child in question which had not been reporting since Feb 28. It is now gone and not coming back. Not sure what I lost.
      Will revert back to supported release .87.
        Try power cycling the thermostat and then rescanning it.
        Cheers
        Al
          Hi Al;
          Loaded .110 back in and power cycled. Same error is reported unfortunately.
          Apr-05 18:34:35 Z-Wave Device: Main Dining Room Temperature Set to 21.1111111111111 (C)
          Apr-05 18:32:59 Z-Wave Warning Z-Wave Multilevel Sensor device Main Dining Room CT32 - Temperature is missing Sensor Type information - cannot update sensor status.
          Apr-05 18:13:25 Z-Wave 7 out of 7 Child devices of node 17 were created successfully.
          Apr-05 18:13:25 Z-Wave Node 17 Supports Thermostat Setpoint CC and supports these setpoints: Heating 1, Cooling 1
          Apr-05 18:13:24 Z-Wave Node 17 Supports Thermostat Mode CC and supports these modes: Off, Heat, Cool
          Apr-05 18:13:24 Z-Wave Node 17 Supports Thermostat Fan Mode CC and supports these modes: Auto, On
          Apr-05 18:13:24 Z-Wave Device: Main Dining Room Temperature Set to 21.3888888888889 (C)
          Apr-05 18:13:24 Z-Wave Node 17 is Z-Wave version: Lib: 2.78 App: 7.4
          Apr-05 18:13:19 Z-Wave Node: 17 Supports Class(es): BASIC_V2, INDICATOR_V2, MANUFACTURER_SPECIFIC_V2, SENSOR_MULTILEVEL_V7, THERMOSTAT_MODE_V2, THERMOSTAT_FAN_MODE_V2, THERMOSTAT_SETPOINT, THERMOSTAT_OPERATING_STATE_V2, VERSION_V2, CONFIGURATION_V4, BATTERY, PROPRIETARY
          Apr-05 18:13:19 Z-Wave Syncing Z-Wave nodes with device list...
          Apr-05 18:13:19 Z-Wave Found 31 Z-Wave nodes
          Apr-05 18:13:19 Z-Wave Getting Z-Wave node list for network C8E9XXXX...
            Not sure what else to suggest at this point. Probably best to email support@homeseer.com to open a case with them.
            Cheers
            Al
