Script command to toggle output?
    Hi, what script command command would you use to toggle this output?
    Output 003 [Garage Door]
    No toggle selection shows under the control button drop downs, only On
    and Off.
    And how would select the toggle time?
    When I try to view the PDF help file my, Acrobat Reader 7 Errors and has to Close, I have no problems with other PDF's.
    Mark
    and Off.
    Mark
    Here is the syntax:
    PHP Code:
    Public Function ControlOutput(ByVal strOutput As String_
                                             ByVal strAction
    As String_
                                             ByVal strOnTime
    As String) As String
    strOutput “001” – “208”
    strAction “On”“Off”“Toggle”
    strOnTime “0” – “65535”
    Here is the sample code:
    PHP Code:
    Sub Main(ByVal parm As Object)
    Toggle output 003 for 60 seconds
      Dim strResults As String = hs.plugin("UltraM1G").ControlOutput("003", "Toggle", "60")
      If strResults.Length > 0 Then
        Call hs.WriteLog("Error", strResults)
      End If
    End Sub
    Can you view this PDF? http://automatedhomeonline.com/HomeS...sers_Guide.pdf
    Ultrajones
      Originally posted by Ultrajones View Post
      Here is the syntax:
      PHP Code:
                                               ByVal strAction
      As String_
                                               ByVal strOnTime
      PHP Code:
        End If
      End Sub
      Ultrajones
      No I can't, that's the PDF Link that gives me the error...
      Mark
        The link works for me,
        tenholde
        tenholde
          tenholde
          Ok, I got it. Their must have been some sort of problem with my PDF
          reader, I was running Ver 7.1. I just removed it and installed the latest ver 9, now all is Good.
          Mark
            Here is the syntax:
            PHP Code:
                                                     ByVal strAction
            As String_
                                                     ByVal strOnTime
            PHP Code:
              End If
            End Sub
            Ultrajones
            Should toggle show up in the drop down section of the HS device control
            page?....only On and Off Show as selections.
            Mark
