I have an event that calls another event which turns on button 3 of my cooper scene controller which then kicks off another event. When my scene 3 button is turned on from another event it's not working. However if I manually run the scene it does work.
Notice in the log where the events worked when I manually ran the event I get 2 messages in the log that the scene is activated, However where it is called by another event I only get the one message in the log that the scene is activated. I guess the second message (highlighted in red) is what is actually triggering the event to turn on the kitchen lights when the scene 3 button in turned on. I'm not getting that message when the event is called from another event.
Am I doing something wrong or is this a bug?
Here's the log which didn't work:
And here's the log when I manually kick off the event which does work:
Below is the event that turns on the scene 3 button (Arrive Home Inside Lights) and the event that is called when the scene 3 button turns on (SC KitchenGarage-3 Kitchen On-a).
Jan-10 12:05:28 AM Z-Wave Device: First Floor Kitchen Scene Controller Garage Button 3 Set to ON
Jan-10 12:05:27 AM Device Control Device: First Floor Kitchen Scene Controller Garage Button 3 to Scene On (255)
Jan-09 11:36:22 PM Z-Wave Device: First Floor Garage Main Lights Set to 255
Jan-09 11:36:21 PM Device Control Device: First Floor Garage Main Lights to On (255)
Jan-09 11:36:21 PM Device Control Device: First Floor Kitchen Scene Controller Garage Button 3 to Scene On (255)
Jan-09 11:36:21 PM Event Event Trigger "Lighting Arrive Home Inside Lights"
Jan-09 11:36:21 PM Event Event Trigger "Lighting Garage Lights On - Bay 1 Open"
Jan-10 12:05:28 AM Event Running script in background: /home/hs3/HomeSeer/scripts/switchsync.vb("Main","54,53")
Jan-10 12:05:28 AM Event Event Trigger "Light Switch Sync Kitchen Table Slave"
Jan-10 12:05:28 AM Device Control Device: First Floor Kitchen Kitchen Table Light Slave to On (99)
Jan-10 12:05:28 AM Event Event Trigger "Scene Controllers SC KitchenGarage-1 Table Light sync from scene on"
Jan-10 12:05:28 AM Z-Wave Device: First Floor Kitchen Scene Controller Stairs Button 1 Set to ON
Jan-10 12:05:28 AM Z-Wave Device: First Floor Kitchen Scene Controller Garage Button 1 Set to ON
Jan-10 12:05:28 AM Z-Wave Device: First Floor Kitchen Scene Controller Stairs Button 3 Set to Indicator On
Jan-10 12:05:28 AM Z-Wave Control: HomeSeer issued a Z-Wave Scene Activation command for scene ID 11 which will be multicast and sent to scene nodes from the list: 24,25
Jan-10 12:05:28 AM Device Control Device: First Floor Kitchen Scene Controller Garage Button 1 to Scene On (255)
Jan-10 12:05:28 AM Event Event Trigger "Scene Controllers SC KitchenGarage-1 Table Light sync from switch on"
Jan-10 12:05:28 AM Z-Wave Device: First Floor Kitchen Kitchen Table Light Slave Set to 99
Jan-10 12:05:28 AM Event Running script in background: /home/hs3/HomeSeer/scripts/switchsync.vb("Main","83,82")
Jan-10 12:05:28 AM Event Event Trigger "Light Switch Sync Kitchen Island Slave"
Jan-10 12:05:28 AM Z-Wave Device: First Floor Kitchen Island Lights Slave Set to 99
Jan-10 12:05:28 AM Z-Wave Device: First Floor Kitchen High Hats Over Counter Set to 99
Jan-10 12:05:28 AM Z-Wave Device: First Floor Kitchen High Hat Sink Set to 99
Jan-10 12:05:28 AM Device Control Device: First Floor Kitchen Kitchen Table Light Slave to On (99) by/from: CAPI Control Handler
Jan-10 12:05:28 AM Event Running script in background: /home/hs3/HomeSeer/scripts/switchsync.vb("Main","53,54")
Jan-10 12:05:28 AM Event Event Trigger "Light Switch Sync Kitchen Table Master"
Jan-10 12:05:28 AM Z-Wave Device: First Floor Kitchen Kitchen Table Light Master Set to 99
Jan-10 12:05:28 AM Device Control Device: First Floor Kitchen Island Lights Slave to On (99) by/from: CAPI Control Handler
Jan-10 12:05:28 AM Event Running script in background: /home/hs3/HomeSeer/scripts/switchsync.vb("Main","82,83")
Jan-10 12:05:28 AM Event Event Trigger "Light Switch Sync Kitchen Island Master"
Jan-10 12:05:28 AM Z-Wave Device: First Floor Kitchen Island Lights Master Set to 99
Jan-10 12:05:28 AM Z-Wave Device: First Floor Kitchen High Hats Over Fridge Set to 99
Jan-10 12:05:28 AM Device Control Device: First Floor Kitchen High Hats Over Counter to On (99)
Jan-10 12:05:28 AM Device Control Device: First Floor Kitchen High Hat Sink to On (99)
Jan-10 12:05:28 AM Device Control Device: First Floor Kitchen Kitchen Table Light Master to On (99)
Jan-10 12:05:28 AM Device Control Device: First Floor Kitchen Island Lights Master to On (99)
Jan-10 12:05:28 AM Device Control Device: First Floor Kitchen High Hats Over Fridge to On (99)
Jan-10 12:05:28 AM Event Event Trigger "Lighting Zones Kitchen On"
Jan-10 12:05:28 AM Event Event Trigger "Scene Controllers SC KitchenGarage-3 Kitchen On-a"
Jan-10 12:05:27 AM Event Event Trigger "Lighting Arrive Home Inside Lights"
Jan-10 12:05:27 AM Event Event Lighting Arrive Home Inside Lights triggered by the event page 'Run' button.
