Setting the cool/heat setpoint is always buggy and unreliable. Will you be able to fix it? I believe you take the nearest value to the current temperature and use that for either heating or cooling setpoints. That doesn't work very reliably. Is there anyway you can take the actual cooling/heading setpoint values instead?
Problem with thermostats
