A storm took out power for 12 hours today. Upon power restoration my HomeSeer server started up far faster than the Philips Hue bridge did. I was looking at my logs and noticed the plugin seemed to remain in a dead state until I manually disabled/enabled the plugin. Should it have reattempted to discover the local bridge and finish its start-up tasks, or is this dead state the currently expected behavior?
Log below.
Log below.
Oct-30 4:49:32 PM JowiHue 1 Temperature sensor(s) found on bridge 'Philips hue' with 1 supporting HS device(s) Oct-30 4:49:32 PM JowiHue 1 Lightlevel sensor(s) found on bridge 'Philips hue' with 1 supporting HS device(s) Oct-30 4:49:32 PM JowiHue 1 Daylight sensor found on bridge 'Philips hue' Oct-30 4:49:32 PM JowiHue 2 Generic status sensor found on bridge 'Philips hue' Oct-30 4:49:32 PM JowiHue -------------------------------------Plugin info --------------------------------------------- Oct-30 4:49:32 PM JowiHue 23 Presets available for use in the JowiHue plugin Oct-30 4:49:32 PM JowiHue 2 Local scenes available for use in the JowiHue plugin Oct-30 4:49:32 PM JowiHue 1 Animations available for use in this plugin Oct-30 4:49:32 PM JowiHue ============================================================================================== Oct-30 4:49:32 PM JowiHue Plugin succesfully started Oct-30 4:49:32 PM JowiHue Enabled Colour Temperature control for group Garage Oct-30 4:49:32 PM JowiHue ============================================================================================== Oct-30 4:49:32 PM JowiHue -------------------------------------Bridge info --------------------------------------------- Oct-30 4:49:32 PM JowiHue 15 lights connected to bridge 'Philips hue' Oct-30 4:49:32 PM JowiHue 14 Groups available on bridge 'Philips hue' Oct-30 4:49:32 PM JowiHue 1 Motion sensor(s) found on bridge 'Philips hue' with 1 supporting HS device(s) Oct-30 4:49:32 PM JowiHue Enabled Hue control for group Garage Oct-30 4:49:31 PM JowiHue Enabled Colour Temperature control for group Master Bathroom Oct-30 4:49:31 PM JowiHue Enabled Hue control for group Master Bathroom Oct-30 4:49:30 PM JowiHue Enabled Colour Temperature control for group 2nd Floor Hallway Oct-30 4:49:30 PM JowiHue Enabled Hue control for group 2nd Floor Hallway Oct-30 4:49:30 PM JowiHue Enabled Colour Temperature control for group Family Room Oct-30 4:49:30 PM JowiHue Enabled Hue control for group Family Room Oct-30 4:49:29 PM JowiHue Enabled Colour Temperature control for group Master Bed Oct-30 4:49:29 PM JowiHue Enabled Hue control for group Master Bed Oct-30 4:49:29 PM JowiHue Enabled Colour Temperature control for group HueHalloweenActiveLightsGroup Oct-30 4:49:28 PM JowiHue Enabled Hue control for group HueHalloweenActiveLightsGroup Oct-30 4:49:27 PM JowiHue Enabled Colour Temperature control for group Mud Room Oct-30 4:49:27 PM JowiHue Enabled Hue control for group Mud Room Oct-30 4:49:25 PM JowiHue * Connected to bridge Philips hue at 192.168.X.XXX Oct-30 4:49:24 PM JowiHue InitIO:Plugin basic initialisation done Oct-30 4:49:24 PM JowiHue Starting plugin JowiHue 2.0.1.0 on Windows . . .Above is where I manually re-enabled the plugin. .Below is from when power restored to when I manually stopped the plugin. . . Oct-30 4:49:17 PM JowiHue JowiHue Plugin is stopped. Thanks for using it :-) Oct-30 4:43:50 PM JowiHue Error: (CheckBridgeUpdate):Object variable or With block variable not set. Oct-30 4:43:50 PM JowiHue Error: (CheckBridgeUpdate):CheckBridgeUpdate Version 1.21.0 Oct-30 3:43:50 PM JowiHue Error: (CheckBridgeUpdate):Object variable or With block variable not set. Oct-30 3:43:50 PM JowiHue Error: (CheckBridgeUpdate):CheckBridgeUpdate Version 1.21.0 Oct-30 2:43:50 PM JowiHue Error: (CheckBridgeUpdate):Object variable or With block variable not set. Oct-30 2:43:50 PM JowiHue Error: (CheckBridgeUpdate):CheckBridgeUpdate Version 1.21.0 Oct-30 1:43:50 PM JowiHue Error: (CheckBridgeUpdate):Object variable or With block variable not set. Oct-30 1:43:50 PM JowiHue Error: (CheckBridgeUpdate):CheckBridgeUpdate Version 1.21.0 Oct-30 12:43:50 PM JowiHue Error: (CheckBridgeUpdate):Object variable or With block variable not set. Oct-30 12:43:50 PM JowiHue Error: (CheckBridgeUpdate):CheckBridgeUpdate Version 1.21.0 Oct-30 12:43:25 PM JowiHue Devices added for new light Mud Porch Ceiling 02 Oct-30 12:43:25 PM JowiHue Devices added for new light Front Door Left Oct-30 12:43:23 PM JowiHue Devices added for new light Front Door Right Oct-30 12:43:22 PM JowiHue Disabled Colour Temperature control for group 2nd Floor Hallway Oct-30 12:43:22 PM JowiHue Disabled Hue control for group HueHalloweenActiveLightsGroup Oct-30 12:43:22 PM JowiHue Disabled Colour Temperature control for group HueHalloweenActiveLightsGroup Oct-30 12:43:22 PM JowiHue Disabled Hue control for group Garage Oct-30 12:43:22 PM JowiHue Disabled Colour Temperature control for group Garage Oct-30 12:43:22 PM JowiHue Disabled Hue control for group Family Room Oct-30 12:43:22 PM JowiHue Disabled Colour Temperature control for group Family Room Oct-30 12:43:22 PM JowiHue Disabled Hue control for group 2nd Floor Hallway Oct-30 12:43:22 PM JowiHue Disabled Colour Temperature control for group Master Bathroom Oct-30 12:43:22 PM JowiHue Disabled Hue control for group Mud Room Oct-30 12:43:22 PM JowiHue Disabled Colour Temperature control for group Mud Room Oct-30 12:43:22 PM JowiHue Disabled Hue control for group Master Bed Oct-30 12:43:22 PM JowiHue Disabled Colour Temperature control for group Master Bed Oct-30 12:43:22 PM JowiHue Disabled Hue control for group Master Bathroom Oct-30 12:43:22 PM JowiHue Devices added for new light Mud Porch Door Oct-30 12:37:51 PM JowiHue Plugin succesfully started Oct-30 12:37:51 PM JowiHue InitPlugin:No registered bridge found; please register a bridge through the configuration page Oct-30 12:37:49 PM JowiHue Bridge device Philips hue not containing a valid IP address, was it reset? Oct-30 12:37:49 PM JowiHue Warning: warning! Missing ipaddress in device for bridge Philips hue, wil try repair Oct-30 12:37:49 PM JowiHue InitIO:Plugin basic initialisation done Oct-30 12:37:49 PM JowiHue Starting plugin JowiHue 2.0.1.0 on Windows
