New to HomeSeer so be kind...
I have installed the Insteon plugin and finally got my HomeSeer install to see the Thermostat however I am getting the following error messages when I try to control it. Ideas on what I am doing wrong? Model of Insteon thermostat is 2441THR Refurbished INSTEON Thermostat. Ideas?
Also having problem with Insteon water leak sensor (never sees the sensor during discovery mode).
Date/Time Pri Type/Error Message/Source
Nov-20 8:02:42 PM Insteon Thermostat Error SetHeatSetpoint: Insteon Thermostat Requested Heat Setpoint 69 has to be within the low(30)/high(125) bounds as configured and less than the cool setpoint 0
Nov-20 8:02:42 PM Insteon Thermostat SetHeatSetpoint: Insteon Thermostat set heat setpoint to 69 Current heat setpoint = 0 Current cool setpoint = 0
Nov-20 8:02:42 PM Insteon Thermostat Error Problem attempting to get thermostat Insteon Thermostat device Cool : The given key was not present in the dictionary.
Nov-20 8:02:42 PM Insteon Thermostat Error Problem attempting to get thermostat Insteon Thermostat device Heat : The given key was not present in the dictionary.
Nov-20 8:02:42 PM Device Control Device: Insteon Thermostats Heating to (69) by/from: CAPI Control Handler
Nov-20 8:02:42 PM HSTouch Server Debug 08:02:42:7813 ~ Client command: (Android:Rodney Phone) REQ:thermostatcommand
Nov-20 8:02:32 PM HSTouch Server Debug 08:02:32:2375 ~ Client command: (Android:Rodney Phone) REQ:energygetall
Nov-20 8:02:32 PM HSTouch Server Debug 08:02:32:1724 ~ SendToClient Android:Rodney Phone Data:THERMOSTATCHANGE|54[3]1[3]1[3]50[3]68[3]78[3]0[3]0[3]0[3]0[3]0[3]True[2]
Nov-20 8:02:32 PM HSTouch Server Debug 08:02:32:1724 ~ THERMOSTAT Change detected
