I'm trying to get mcstemp setup to pull weatherxml files directly from weather.com (using 5.30). I've got all the necessary reg stuff done, and I can pull a valid xml file directly. But when I select "Get From WeatherXML Site" I start seeing the following error message in the log:
mcsTemperature WeatherXML on line 480 Path not found
This apparently coincides with with the first http access attempt, and starts repeating (once a minute or so?) from then on until I turn the option back off. When this happens I see a file named "~TempWeather.txt" show up and then disappear in data\mcstemperature - if I grab this file, it appears to be the proper xml file from weather.com.
Haven't seen anything else vaguely similar here, so I'm looking for ideas...
Jerry
Jerry
