Old June 23rd, 2018, 10:02 AM
onepointbrewing onepointbrewing is offline
How to make 2 virtual devices mirror each other?
I have many (10) virtual devices that are tri-state devices (0,1,2 or off,on,nostate) and i'd like to be able to make another set of devices that mirror two of those states (0,1 / off,on) as statuses (used in HSTouch).
Can someone suggest an easy way of achieving this without having to make events for each of the virtual devices.
Old June 23rd, 2018, 01:16 PM
DSteiNeuro DSteiNeuro is offline
Location: Audrey Land (Somewhere near San Diego CA USA)
If I understand what you are asking, I think that this would be a great feature.
The reason is that I would like to look at device status at different device locations on HSTouch.
For example alarm status on both the Alarm and House Status pages.
DSteiNeuro
HS3Pro
Enabled Plug-Ins
Old June 24th, 2018, 11:46 PM
jumper4000's Avatar
jumper4000 jumper4000 is offline
You can do that pretty easily using the "EasyTrigger" Plugin. If you don't want to use a plugin, then you might have to write a script.
Magic mirror freeon HomeSeer General Discussion Area 0 May 27th, 2016 04:30 PM
Why make a Virtual to make this work? Rotech HomeSeer General Discussion Area 1 July 21st, 2014 10:53 AM
Make aNew Virtual temp Daarn RFXCOM Plug-In (3P) 0 May 20th, 2014 06:33 AM
What to use to mirror your HD? Rotech Personal Computers 48 July 4th, 2012 10:11 AM
Make Devices gearyt Bitwise Controls BC4 6 June 9th, 2010 07:13 PM
