Really strange one that has wiped out my entire morning...
Had HS3 working fantastic with an old Aeotec Z-Stick on a temporary Pi. Couldn't be happier.
Now have my new Pi, a Z-Wave.ME UZB stick, and set everything up from scratch. All smooth.
Aeotec motion sensors working perfectly - live readings of movement and various other readouts.
Figaro switches, Fibaro dimmers, and Aeotec MultiSwitches do not report live readings. e.g. I can turn an Aeotec switch of a Fibaro light on and off, and the status does not change in HomeSeer.
HomeSeer can still control the device, it simply gets no readings.
Now here is the really weird thing.... if I remove the group 1 (lifeline) association and add it back, everything works perfectly... for 5 seconds. Any switching I do in that 5 seconds responds instantly. After around 5 seconds, things don't work again. Remove the association, put it back on, and I once again get 5 seconds worth.
After it stops working there are NO entries in the log for things being turned on and off, it's like the signal never happened. Have tried switching to the BETA Z-Wave plugin, no change.
The Z-Wave.ME UZB has the latest firmware, HS3 is fully up to date, everything looks fantastic... just that lifeline association only works for 5 seconds. Have wasted my entire morning trying to work this out and now at a point where hopefully someone has an obvious answer (other than turning on polling, would hate to flood my network with that when live changes were working fantastically until this morning).
