Next beta cycle. As always make a backup of your insteon.ini and homeseer database before upgrading.
Changes:
- Added sorting feature to Device Manage page. Click column heading once for asc sort, click again for desc sort. Currently, your sort option will not persist between plugin restarts. (3.0.6.4)
- Added Siren Module (2868) support; this device superceeds the Alert Module (3.0.6.5)
- Revised link display text to support Siren module Responder (3.0.6.5)
- Revised dimmer sliders to include max value 100. This will allow setting 100% On via the slider regardless of default on-level. See Note 1 below. (3.0.6.6)
- Disables polling for devices that do not respond after 2 failed attempts (3.0.6.9). See Note #2 below to disable this feature.
- Revised Insteon Receive message format to include HS Location2 (3.0.6.10)
- Added Motion Sensor II support (3.0.6.12) -- see the following thread for details https://forums.homeseer.com/showthread.php?p=1301377
- Revised MS II support (3.0.6.13)
- Revised MS II support (3.0.6.14)
- Added some additional Configuration Change Trigger calls (3.0.6.17)
- Manages the insteon.ini file internally; does not use the HS3 methods. See Note #3 below (3.0.6.17)
- Revised ini management routines. The insteon.ini will be re-saved about 3 seconds after any required changes (comm stats, polling results, or config changes) (3.0.6.18)
- Device value set to -1 (Unknown) if polling fails (3.0.6.23)
- Changed the default value for the Hub setting GetXMLBufferInterval=2000 (3.0.6.24)
- Syncing linked responder devices now use the responder link values to set the on level and ramp rate (3.0.6.24, 3.0.6.26)
- Revised MS II timeout option list (3.0.6.27)
- Hub.GetBuffer routine won't generate report log files on exceptions; now logs a Normal msg (3.0.6.25, 3.0.6.28)
- Added 'Display Relay Polling" option to IOLincs. Use this option if polling is triggering the relay (3.0.6.30)
- The Interface Port help text on the Config page will now display the list of available ports (3.0.6.0.30)
- Added support for "Do not log commands from this device:" option implemented for MS II (3.0.6.31)
- Added an Insteon tab on the hs devices edit pages that includes links to the plugin (3.0.6.31)
- Allows empty or blank group locations to better support Alexa (3.0.6.33)
- Small improvement to Hub II buffer processing (3.0.6.34)
- Revised logging for Hub network errors; no functional changes (3.0.6.35)
- Added additional message processing for new Hub messages (3.0.6.36)
- Added Light Sensitivity setting to MS II (3.0.6.37)
- Removed the non-functioning sensitivity setting and add 3 settings: Dark threshold, Light Threshold, and a Transition Interval delay (3.0.6.38)
- Revised setting value lists for MS II (3.0.6.39)
- Revised Hidden Door Sensor support; added 2 Groups option - see user's manual (3.0.6.41)
- MSII temp, light level, battery level will update last change date with heartbeat date (3.0.6.43)
- Added EZsnsRF basic support (you must link manually) (3.0.6.47)
Fixes:
- An error (can't write to log file) associated with External Device registration. (3.0.6.4)
- A bug when display sub device on add/Create Group page (3.0.6.5)
- An error when using All Off buttonwith Controlinc (3.0.6.5)
- Registration of old motion sensors (fw 30 or older) (3.0.6.8)
- IOLinc polling fix attempt (3.0.6.8)
- IOLinc polling fix attempt #2 (3.0.6.9)
- Resolved X10 control issue (3.0.6.9)
- Revised KPL HS Devices sync with KPL LEDs (3.0.6.15)
- Revised KPL HS Devices sync when using radio or combine button groups (3.0.6.16)
- A bug when programming a group without a controller (3.0.6.16)
- A bug with original motion sensors causing exceptions (3.0.6.18)
- a bug related MS II heartbeat battery level reporting (3.0.6.19)
- X10 polling for dimmers supporting preset dim (3.0.6.21)
- Config folder name change for Linux (3.0.6.21)
- IOLinc polling fix attempt #3 (3.0.6.23)
- KPL hs device syncing (3.0.6.23)
- On-level and ramp rates in group definition for KPL Load device #9 (3.0.6.28)
- X10 processing will ignore X10 messages for devices owned by other plugins (3.0.6.29)
- Fanlinc/Keypadlinc control from HS dev management page (3.0.6.31)
- KPL and switchlinc syncing (3.0.6.32)
- Device syncing will not propagate the Beep command (3.0.6.33)
- Unknown group broadcasts will not generate an exception/error report; just logged (3.0.6.40)
- Increased field space on Insteon ID fields (3.0.6.40)
- Linux dimmer image reference (3.0.6.43)
Please post any issues with this beta to this thread.
Notes:
1. You will need to either manually change the slider definition by changing the max value from 99 to 100 or add RecreateDevices=1 to the [config] section of the insteon.ini and restart the plugin.
2. add FailedPollThreshold=0 to the [config] section of the insteon.ini to continue to poll devices that do not respond. The default value is 2. Change the setting as required. (3.0.6.11)
3. Starting with 3.0.6.17, I have incorporated my own ini file management routines in an effort to avoid losing the insteon.ini file when HS3 crashes or terminates unexpectedly. The ini file will get reordered/sorted by section and key when its saved but nothing should get lost. (3.0.6.17)
Changes:
Fixes:
Notes:
