Here my problem, I have a node that I can't remove from my Z-Net network.
I went in the problematic device Z-Wave tab and did a ''Remove Bad Node' and I had an error message saying the device could not be removed, I went in the log and had the following message:
Znet: Node 3 was not removed because the interface Znet does not have that node in its memory. (It may already be removed.)
So I went in my controler page and looked at the controler node information and here are the nodes found:
Nodes in the Controller
1, 3, 4, 5, 6, 8, 9, 10, 11, 12, 13, 14, 15, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29
30, 33, 35, 36, 38, 39, 40, 41, 44, 45, 46, 47, 57, 58, 60, 61, 62, 69, 70, 71, 75, 76, 79
I stopped the Z-Wave interface and restarted it but the node stays in the controler node list
My question now is how can I remove that Node 3 ?
HS3 Pro Edition 3.0.0.368 (Windows)
Z-Wave Plugin 3.0.1.190
Z-NET V2 Configuration - Version 1.0.23
