Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer General Discussion Area
HomeSeer General Discussion Area General discussion about HomeSeer that does not fall into any other category or are not specific to 1.x or 2.x versions of HomeSeer.
Old June 14th, 2018, 12:47 PM
socalsharky socalsharky is offline
Seer
Looking to Automate My Whole House Fans
I have 3 whole house fans that I would like to automate. I will eventually be using a thermostat and HS3 to turn the fans off and on as needed.
The fans are currently controlled with a single-gang triple switch (for on-off control of each individual fan) wired in series with a Lutron push button timer switch. The timer switch has buttons for 2,4,8,12 hours.
I would like to use either Zwave or RadioRA2 to control the fans. So far I can't find anything smart like the single gang triple switch that I am using now. I thought of just using smart plugs up in the attic, but I still want local control for my wife and kids. I would also rather not use a 4-gang box for all of the switches that would be required if I go with full size devices. Is there a way to accomplish this with some smart plugs/switches in the attic and relays?
Old June 14th, 2018, 01:14 PM
cowinger cowinger is online now
Seer Master
Using any of the smart plugs (if rated for motors) would still work and then where the triple switch is those wires could be wired together and a face plate. Using a remote like the ZRC-90US or a Wall Mote, etc. to turn on each individual fan. I assume the fans are plugged into an outlet in the attic? If so the zen15 might work better for motor control than a smart plug because of inrush current.
HTML code is Off
Airscape Whole house fans sirmeili HomeSeer General Discussion Area 0 February 12th, 2018 01:17 PM
Ceiling Fans ksum HomeSeer and Google Home 3 October 31st, 2017 10:04 AM
RF Ceiling fans The Profit SimpleRF (3P) 2 February 20th, 2017 08:14 PM
attic and fans.... TeleFragger HomeSeer General Discussion Area 10 July 5th, 2008 05:59 PM
Booster Fans... Kbevo General Home Automation Hardware Discussion 7 October 24th, 2006 06:17 PM
