Screenshots showing initial install steps for mcsTemperture under HS2
mcsTemperature HS2 Install Instructions
klona
HI,
I surely have mis-do something, but I can't managage to try mcstemp.
As i really dont want to do testing on my working HS 2.0, I download an install a fresh 30 days trial HS 2.2 on a separated PC, with a clean new XP install.
Then copy mcstemp exe in HS22 home dir and restart it. Then enabled it in the interface section. There is no mcstemp setup in GUI or web in HS22, and I get the following error in the log :
7/12/2007 2:04:38 PM - Error - License file mcsTemperature.lf does not exist
Any idea on my mistake ?
Run the updater from your new HS2 install to install mcsTemperature on it. Alternately you can get the mcsTemperature install file from http://mcsSprinklers.com/setup_mcsTemperature.exe into your new Homeseer 2 folder.
klona
Just tried to let the updater install the latest version as i am still on 5.7.0.0.
consistently get the message:
<TABLE cellSpacing=2 cellPadding=0 width="100%" border=0><TBODY><TR><TD class=LOGDateTime0 noWrap align=left>19/08/2007 23:24:11 </TD><TD class=LOGType0 align=left colSpan=3>Updater </TD><TD class=LOGEntry0 align=left colSpan=8>Error accessing remote update server: ERROR: The remote server returned an error: (400) Bad Request.</TD></TR><TR><TD class=LOGDateTime1 noWrap align=left>19/08/2007 23:24:11 </TD><TD class=LOGType1 align=left colSpan=3>Updater </TD><TD class=LOGEntry1 align=left colSpan=8>Error accessing remote update server: ERROR: The remote server returned an error: (400) Bad Request.</TD></TR><TR><TD class=LOGDateTime0 noWrap align=left>19/08/2007 23:24:12 </TD><TD class=LOGType0 align=left colSpan=3>Updater </TD><TD class=LOGEntry0 align=left colSpan=8>Error accessing remote update server: ERROR: The remote server returned an error: (400) Bad Request.</TD></TR><TR><TD class=LOGDateTime1 noWrap align=left>19/08/2007 23:24:41 </TD><TD class=LOGType1 align=left colSpan=3>Updater </TD><TD class=LOGEntry1 align=left colSpan=8>Starting download of updates</TD></TR><TR><TD class=LOGDateTime0 noWrap align=left>19/08/2007 23:24:41 </TD><TD class=LOGType0 align=left colSpan=3>Updater </TD><TD class=LOGEntry0 align=left colSpan=8>Downloading update: mcsTemperature</TD></TR><TR><TD class=LOGDateTime1 noWrap align=left>19/08/2007 23:24:42 </TD><TD class=LOGType1 align=left colSpan=3>Updater </TD><TD class=LOGEntry1 align=left colSpan=8>Error downloading file: The remote server returned an error: (404) Not Found.</TD></TR><TR><TD class=LOGDateTime0 noWrap align=left>19/08/2007 23:24:42 </TD><TD class=LOGType0 align=left colSpan=3>Updater </TD><TD class=LOGEntry0 align=left colSpan=8>WARNING: There were no packages successfully downloaded for installation.</TD></TR></TBODY></TABLE>
Any ideas?
chrisbor
Hi
When I launch MCS temperature plugin with the GIU I've this error
Script error: Type mismatch: '[string: "Faux"]'
If Not hs.GetINISetting("Web Agent", "AllowGuest", False, "mcsGuest.ini") Then
If Request.ServerVariables("AUTH_USER") = "guest" Then
Have you an idea please
thank's
Error in accessing setup screen
When trying to access the setup screen I get the following error: any ideas?
HTTP/1.1 404 OK Server: HomeSeer
HomeSeer internal error
File: D:\Program Files\HomeSeer 2\html\/includes/style.asp HTTP/1.1 404 OK Server: HomeSeer
File: D:\Program Files\HomeSeer 2\html\/includes/header.asp<SCRIPT language=JavaScript>function clearSubmit(button) { // put ... in the face of the submit button and copy the button to clientAction // ClientAction captures the last button pressed before a submit // if the Select / Upate toggle button was hit and update requested or another // button was hit and the mode is for update then submit the form document.MovementForm.ClientAction.value = button.name; if (button.name == "GroupFilter") { document.MovementForm.DeviceFilter.value = "N/A"; } if (button.name == "DeviceFilter") { document.MovementForm.GroupFilter.value = "N/A"; } if (button.value == "Update") { button.value = "Updating"; document.MovementForm.submit(); }}// Special case of <Return> form text box that could not be vectored with onChangefunction CheckText() { var result; if (document.MovementForm.ClientAction.value == "") { document.MovementForm.ClientAction.value = "EndDate"; } if (document.MovementForm.Update.value == "Select") { document.MovementForm.Update.value = "Updating"; result = true; } else { result = false; } return result;}</SCRIPT>
Script error: Exception from HRESULT: 0x800A000D
response.write CustomHeader(Array(fs4.Value, "", gBackgroundColor, "", gStyleSheet))
Else</PRE>
This is authorization code that has been in mcsTemperature.asp in the \HTML subfolder for quite awhile. I thought it was already removed, but I guess not. The segment below is likely what you have.
Code:'Temperature ASP 'v1.0 10-10-02 M. McSharry Dim x 'Redirect for unauthorized users If Not hs.GetINISetting("Web Agent", "AllowGuest", False, "mcsGuest.ini") Then If Request.ServerVariables("AUTH_USER") = "guest" Then Response.redirect ("/unauthorized.asp") End If End If 'Process the request Response.Write hs.plugin("mcsTemperature").TemperatureASP(request, response)
Code:Response.Write hs.plugin("mcsTemperature").TemperatureASP(request, response)
mcsTemperature is downloaded by the HS Updater as mcsTemperature_5_12_0_7.zip. That files contains the mcsTemperature.lf for licensing and setup_mcsTemperature.exe which is an installer executable. If you would not prompted for install path etc from this installer then it did not install. I would suggest searching for this .exe in a subfolder under Homeseer 2 and then execute it.
The messages related to header.asp and style.asp are from the "includes" download which was used with a very early version of mcsTemperature and is still supported for backward compatibilty with the "compatibliy mode" checkbox on the setup. If you do not have any \Config\mcsTemperature.ini file present then it should default to not using these "includes"
chrisbor
Error launching
Hi michael,
Thank's for your help , it's good
Regards
Originally posted by Michael McSharry View PostThis is authorization code that has been in mcsTemperature.asp in the \HTML subfolder for quite awhile. I thought it was already removed, but I guess not. The segment below is likely what you have.
Spoke too soon - the following comes up in the log:
2/13/2008 12:36:06 AM - Info - Initializing Plug-in: mcsTemperature
2/13/2008 12:36:06 AM - mcsTemperature - Version 5.12.7 Registered with Homeseer
2/13/2008 12:36:06 AM - COM Plugin - Calling InitIO
2/13/2008 12:36:07 AM - mcsTemperature - InitINIVariables sensorType=0, index=0 on line 8040 ActiveX component can't create object
2/13/2008 12:36:07 AM - mcsTemperature - Temperature database Table D:\Program Files\HomeSeer 2\mcsTemperature.mdb\Temperature has no data stored
2/13/2008 12:36:07 AM - Info - Finished initializing plug-in mcsTemperature
Is this something to do with the install of device drivers for DS9097 or drivers for line graphs - I've installed Java.
This message is from the 1-wire drivers not being installed. Sun Java will not work. Microsoft Java Virtual Machine (MS JVM) must be installed then the drivers for 1-wire. MS JVM can be found via google search. The drivers are at ftp://ftp.dalsemi.com/pub/auto_id/li...ivers_v400.msi.
