So I have my wifi2ir and the global cache pro plugin. If I want to switch the set top box to channel 2, the capi commnd string would be hs.CAPIControlHandler(hs.CAPIGetSingleControl(704,True,"DIGI T 2",False,False)). If I understand the way the wifi2ir would send commands to issue a channel of say 29, I'm guessing that there would be two command strings sent. One for the 2, then one for the 9.
How would the method be created to send capi1 command + capi2 command +... ???
Is this the preferred method or are there other suggestions that would work?
The ultimate goal here is to use Jon's alexa script and pass in the integer for the channel I want, from my echo, do some parsing which I then think would need to be broken down to multiple send commands. So for example, it I say change the channel to 29, two command strings would be sent to the wifi2ir from within the script.
Robert
Robert
