Icons
    Icons
    Hello, I am a NEWBIE when it comes to HS.... Not sure where to post this question but this seems appropriate... I want to change the icons displayed for a device... How do I do that? .. the reason I ask is that for some reason 2 of my devices have changed after I install the z-wave thermostat plug in. These is one dimmer and one relay and both now appear as "thermostats" I can no longer control then either (no on/off/dim options).... Any thoughts as to how I can revert these 2 devices back?
    To clear any device in HomeSeer you can use this command in the control and then immediate section. &hs.setDeviceString "A1", clear changing the A1 to the code for the device you want to change. Keep in mind that some plugins will change this each time HS is restarted.
      Thanks.. Will try that later on....
