I set 2 TCP modbus devices, my Barionet (Barix) and my Tbox (Servelec).
I can access my registers (int) without problems.
But with my TBox, the poll doesn't work by itself (set to 1 minute) and I NEED to check/uncheck the Zero-based addressing parameter to allow HS to poll correctly my unit.
I also played with the Big-Endian values (checked/unchecked) to see the difference: none
TBox settings
Gateway: IP address
TCP port: 502
Poll interval: 1 min
Gateway enabled: checked
Disable Big-Endian values: checked
Zero-based addressing: unchecked
Retries: 2
Timeout: 1000
Delay: 1000
register write function: Multiple
TBox register settings
Gateway: TBox
Type: Holding Register (RW)
Slave ID: 1
Register address : same as Tbox modbus address
Return Type: int16
Signed: checked
Multiplier: 1
Read only: unchecked
Enabled: checked
Note: The Tbox and Barionet are managing correctly the registers (poll ok) and Modbus Poll prgm is accessing correctly the registers too.
Where is my error ?
Current Date/Time: 2018-01-01 01:08:48
Operating System: Microsoft Windows 7 Professionnel - Work Station
System Uptime: 0 Days 6 Hours 51 Minutes 26 Seconds
IP Address: 192.168.1.154
Number of Devices: 18
Number of Events: 10
Available Threads: 200
Enabled Plug-Ins
3.9.6431.26038: Modbus
3.0.0.14: NetCAM
TBox settings
Gateway: IP address
TCP port: 502
Retries: 2
Timeout: 1000
Delay: 1000
Gateway: TBox
Slave ID: 1
Return Type: int16
Signed: checked
Multiplier: 1
Enabled: checked
Where is my error ?
Enabled Plug-Ins
3.0.0.14: NetCAM
