Beta Update
Version 3.0.1.1
* Expires 3/31/18
* Removed button for saving device command settings. It's not needed as they are saved automatically now.
Working on...
I started on adding a new feature to allow you to set the sleep timer and also monitor when a sleep timer is set on the Hub.
The Device will have 5 default controls: Cancel timer, and buttons for setting 15, 30, 60, 90 and 120 minute sleep timers. You will be able to add your own controls for other sleep timer values in the status tab of the device options if you want.
The Device status will be either "No Timer Set" or a countdown of the timer. The value will be the seconds left until the timer expires.
I plan on adding an action for:
I plan on adding Triggers for:
Sample use case: I sometimes sleep in the living room (when I can't sleep and just want to watch TV). I have a virtual device and events that keep the ceiling fan going if the virtual devce for "sleeping in living room" is turned on. Those nights I normally set the sleep timer on the harmony remote and turn on the VD "Sleeping in the living room"
I could now have events that say if it's night, and a sleep timer is set to turn on the VD.
I could have another that says that if it's night and "sleeping in the living room" is turned on and there is no sleep timer, then set a sleep timer.
Thoughts or suggestions on this feature?
Version 3.0.1.1
* Expires 3/31/18
Working on...
- setting a sleep timer via an event to any value you want (i.e. Set a sleep timer for 93 minutes).
- When a sleep timer is set.
- When a sleep timer is cancelled.
- When a sleep timer reaches a certain value (This may not be added if it can be done via a normal trigger "a device has a value")
