I have many hourly repeating errors in the HSPRO log file for VWS.
Exception error in ProcessDBaseData()-->UpdateHSDeviceString-2: System.OverflowException: Arithmetic operation resulted in an overflow. at Microsoft.VisualBasic.CompilerServices.Conversions.ToInteger (Object Value) at Microsoft.VisualBasic.CompilerServices.Conversions.ChangeInt rinsicType(Object Expression, Type TargetType) at Microsoft.VisualBasic.CompilerServices.Conversions.ChangeTyp e(Object Expression, Type TargetType) at Microsoft.VisualBasic.CompilerServices.OverloadResolution.Pa ssToParameter(Object Argument, ParameterInfo Parameter, Type ParameterType) at Microsoft.VisualBasic.CompilerServices.OverloadResolution.Ma tchArguments(Method TargetProcedure, Object[] Arguments, Object[] MatchedArguments) at Microsoft.VisualBasic.CompilerServices.NewLateBinding.Constr uctCallArguments(Method TargetProcedure, Object[] Arguments, BindingFlags LookupFlags) at Microsoft.VisualBasic.CompilerServices.Symbols.Container.Inv okeMethod(Method TargetProcedure, Object[] Arguments, Boolean[] CopyBack, BindingFlags Flags) at Microsoft.VisualBasic.CompilerServices.NewLateBinding.CallMe thod(Container BaseReference, String MethodName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack, BindingFlags InvocationFlags, Boolean ReportErrors, ResolutionFailure& Failure) at Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateCa ll(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack, Boolean IgnoreReturn) at HSPI_VWS.Module1.UpdateHSDeviceString(Int32& DevID, String NewString, Object DevVal, Boolean AllowScale) at HSPI_VWS.Module1.ProcessDBaseData()
The HSDeviceString-2 may be out of the upper bounds or may simply not exist? Not sure. Do not remember making any changes that may have caused this issue to appear. This may have started after a windows 7 update.
See attached .txt file for vws debug log enabled
V14.01 P25 for Ambient Virtual Weather Station Internet Edition
2.2.0.29 for VWS in HSPRO 2.5.0.20
Thoughts?
Thoughts?
