HS3 Plugin List
Originally posted by Rupp View PostYes, this is coming in the next week or so.
Thank you,
Kevin
seanpodonohue
Any Update's on Insteon or ISY interfaces?
Rupp said 2 weeks a long time ago.
All my 40+ Insteon Devices are currently controlled by an ISY99i.
But since all devices need to be added from scratch, I might do it all using the PLM interface.
Originally posted by seanpodonohue View PostRupp said 2 weeks a long time ago.
Upgrade HS2 to HS3 insteon
I'm currently using older version of 2414U insteon controller , which is working fine with the default HS2 plugin HYBRID PLC VERSION 1.1.52.1 In PLC/SDM Mode. provided by Homeseer.
Move to HS3 do I have to purchase new insteon controller and plugin from Mark Sander?
Originally posted by ptran0 View PostI'm currently using older version of 2414U insteon controller , which is working fine with the default HS2 plugin HYBRID PLC VERSION 1.1.52.1 In PLC/SDM Mode. provided by Homeseer.
I would recommend the 2413S (serial if you have the com port). otherwise the 2413U is a good alternative.
the new Insteon Hub is also supported with my plugin
the RF Dongle is also supported if you want to go completely RF
these are all supposed in HS2 and will be in HS3Mark
HS3 Pro 4.2.19.5
