Originally posted by terrence989
View Post
EnvisaLink DSC Plug-in - Feature requests
Originally posted by terrence989 View PostHi,
I am HS3 PRO user, please recommend which interface work better for the below : -
Envisalink EVL3 or DSC IT-100 interface
Thank you
I prefer the ethernet interface over SerialUbuntu on the Intel NUC ( 8i5BEK ), 32 G, 250G SSD, V4 Pro 😎
Selective logging within Info
Hi Spud,
I'm getting a whopping amount of logging in Info mode because of a motion detector which happens to be central to most traffic in the house.
1- Any chance of implementing selective Info logging by Zone where I could pick which zones get logging.
2- Let me push my luck just a bit further. Could you also create another Envisalink action that would turn logging Off/On for a particular zone? This would allow users to set up events to activate logging for particular zones depending on who disarms the panel, sweet.
EDIT - Just tried it on .17: works great, thanks
EDIT - Any chances on this one? For me, this one complements #1. Normally, I don't want to flood the log with Motion detector traffic; but for someone I gave a temporary password to come and do work while I'm away, I would like the ability to turn on logging for certain zones (ex: Motion detector).
Not sure it's possible but could you display how the zones are configured? I just saw a great example in Rien du Pre's Caddx plugin with a whole column for zone types.
http://board.homeseer.com/showpost.p...3&postcount=10
Would be super cool.Originally posted by rpradeThere is no rhyme or reason to the anarchy a defective Z-Wave device can cause
Originally posted by S-F View PostNot sure it's possible but could you display how the zones are configured? I just saw a great example in Rien du Pre's Caddx plugin with a whole column for zone types.
Originally posted by spud View Postunfortunately I don't think there is any way to get the zone type using the envisalink API.
Yeah, I was afraid of that but figured I'd ask any way.
ThanksOriginally posted by rpradeThere is no rhyme or reason to the anarchy a defective Z-Wave device can cause
A better string for partition device
Hi Spud,
I was used with my later Caddx to have a script maintaining the list of opened zone and updating a device string at every change.
This would change the Partition device text string from "Not Ready"
to "Opened zones: Entry door, main-room window left".
I just adapted the script for Envisalink-DSC and HS3, but did not find a nice way to trigger it (Best would be "at any change in any zone").
I did have a callback instruction in my HS2 setup, but do not feel comfortable using this in HS3.
I guess this could be a nice feature for the plugin, and a more elegant way than external script.
A new envisalink trigger "at any change in any zone" would be appreciated as an alternative.
PierreAttached FilesVisit zee e-maison : http://www.e-maison.com
